Deck install
drews vibe
Deck install
Post by drews vibe »
Hey guys I just picked up an after market deck for my 2005 vibe....do I need any special connecting adapter other than the standard wiring harness. Is anything other than the radio tied into the factory harness? Also how hard is it to remove the factory deck?I just have the base deck no monsoon setup.
Joli
Re: Deck install (drews vibe)
Post by Joli »
more than likely you will need s kit, I know you can get kit for wiring and faceplate from Crutchfields, not sure about other sources for them. I'm sure SOMEONE will have a site or two
05 AWD Silver Vibe | WeartherTech Vent Shades | JVC XG700 HU | Blue Vibe & Red Grafxwerks badge overlays |
aradlaw
Post by aradlaw »
Here is the link to THE GREAT HOW-TO MODIFICATION INDEX! section of the forum on head deck installshttp://forums.genvibe.com/zerothread?id=30794Let us know how it turns out, it's something I need to do eventually.
Sublimewind
Re: Deck install (aradlaw)
Post by Sublimewind »
Quote, originally posted by aradlaw »Here is the link to THE GREAT HOW-TO MODIFICATION INDEX! section of the forum on head deck installshttp://forums.genvibe.com/zerothread?id=30794Let us know how it turns out, it's something I need to do eventually.Wow, after re-reading that, I did a nice job on that tutorial, if I do say so myself...
aradlaw
Re: Deck install (Sublimewind)
Post by aradlaw »
Yes, your tutorial helped out a lot, 'specially removing the dash cover.My sons chipped in and got me a Sony CDX-GT420U for Father's Day, with USB, aux, mp3... ... just the stock speakers, no sub - as long as I can hear it My one son did the wiring harness, I put together the dash kit and the whole thing installed and works very well.
WaveAction
Post by WaveAction »
looks awesome man, im picking up a deck my self hopefully next week or the week after, Alpine CDA-9886, cant wait, i need to get the harness and the dash kit
kunkstyle
Re: (WaveAction)
Post by kunkstyle »
Quote, originally posted by WaveAction »i need to get the harness and the dash kitAnd an FM antenna adapter.
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
WaveAction
ya that too..shouldnt the stock FM adapter work? it worked fine with my pioneer deck in my sunfire
kunkstyle
Re: (WaveAction)
Post by kunkstyle »
Maybe it will. I've been wrong before. The Vibe HU was the only install I haven't done in my garage, so I'm not sure.
WaveAction
hmm well it seems to be the same deck as my sunfire...but after reading sublimes extensive how-to on a deck install i would need one cause apparently the stock one is smaller then normal, right now i only listen to the radio cause i dont got that many cd's and now that i have my mp3 player i probably will never listen to the radio..
tribalman
Re: (WaveAction)
Post by tribalman »
if you have an ipod and your deck supports it, i really recommend getting this cable that allows you to use the dock port instead of using the headphone jack. i prefer to use the HU's controls to navigate through the ipod over the spin wheel. plus if you are using the headphone jack, you might end up accidentally turning up the volume on the ipod thereby making the music get too loud for your tastes, or blow out a speaker.http://www.putfile.com/pic/6597619
None. Vibe is gone.
Sublimewind
Quote, originally posted by aradlaw »Yes, your tutorial helped out a lot, 'specially removing the dash cover.My sons chipped in and got me a Sony CDX-GT420U for Father's Day, with USB, aux, mp3... ... just the stock speakers, no sub - as long as I can hear it My one son did the wiring harness, I put together the dash kit and the whole thing installed and works very well. Looks great man, congratz and a great project for you and the kids..!!! The only thing I don't like about the dash kit, is the little pocket is so little, I can't even get my fingers all the way to the back of it...DOH...
aradlaw
Post by aradlaw »
Thanks, at least with the pocket I may be able to keep track of the remote and a USB key or two.Next project has to be an additional 12v outlet or two
Sublimewind
Quote, originally posted by aradlaw »Thanks, at least with the pocket I may be able to keep track of the remote and a USB key or two.Next project has to be an additional 12v outlet or two You know about the one in the bottom of the center console right?
aradlaw
Post by aradlaw »
Thanks, yes, i've seen that tutorial
elrodvoss
Post by elrodvoss »
Quick Question:I know that the new dask kit is made to have the little "pocket" in it, but here is an odd question:Can I install the project kit upside-down so that the receiver is on the bottom and the pocket is on top?I ask this cause im looking at getting a receiver that has a screen on it. Here is a picture of the unit from crutchfield.http://www.crutchfield.com/App...=5684The reason for this is I also plan on getting the ProClip system for my Treo and it mounts between the air vent and the hazard button. With the screen, that might get in the way.With moving the receiver to the bottom of the kit, that may give me enough room to have the Treo mounted there and the screen out.Or if anyone has any other mounting suggestions for my phone, I would be happy to hear it.Thanks in advance.
aradlaw
Post by aradlaw »
If I remember correctly, the side pieces of the dash insert only fit the front bit one way (right side up) and the mounting screw tabs were angled to align that way. Of course I may be wrong.
tribalman
Re: (elrodvoss)
Post by tribalman »
Quote, originally posted by elrodvoss »Quick Question:I know that the new dask kit is made to have the little "pocket" in it, but here is an odd question:Can I install the project kit upside-down so that the receiver is on the bottom and the pocket is on top?Thanks in advance.aradlaw is correct, the insert only can go in one way. i'm sure there is a kit somewhere that has and upside down insert.
None. Vibe is gone.
Sublimewind
Much depends on the dash kit, some may be able to, the one I got from Metra products (in my install tutorial) can't... Metra isn't the only ones that make dash kits though...
