I just purchased a set of Sunpro elec. gauges (ammeter, oil press & temp.). I need a couple questions answered before I can install them. First, what are the exact sizes of the oil and temp. sending units so that I can get metric adapters. Second, does out temp. sending unit affect our ECU (Vibe GT)? If so, I will have to find another location for the temp. sending unit. If I have to relocate the gauge sending unit, where should this be done and what size is that location.Anybody's help will be greatly appreciated.
'03 Vibe GT"White Lightning"NAV Sys.6 Disk CD Changer17" Wheels w/ Dunlop ZR TiresBomz CAI
I've got an AEM alternator pully on the way. I took off my Bomz intake and made my own Ram Air. It works great. If you touch the ram hose even when the engine is hot, it is cool.
I converted your picture to a .jpg file, and "compressed" it a little. (It's only 54,000k instead of 750,000k)Where are you planning on putting the gauges? I wouldn't mind a mechanical oil pressure gauge, but unsure where to put it.
It is raining pretty hard outside but I took a quick pic from the outside. I will get pics under the hood tomorrow. anyway, I took the stock airbox bottom, turned it upside down, attached a K&N for a stock airbox and took an air scoop for an A/C diffusser and used small long nuts and bolts to attach it to the air box. The hose is 3" aluminum tubing for HVAC applications. I know, it looks ghetto but it works great. The hose is almost COLD after repeated lift runs. I even had 2 small Ram Air decals made and put them on the bumper.
