Will Scion TC Wheel spacers work on Vibe/Matrix?
Kamikaze
Post by Kamikaze »
I've been thinking about doing a 20mm wheel spacer on the back to kick out the back tires just a little bit... I found a decent deal on some good wheel spacers, but they supposedly made for the Scion TC... same 5x100 bolt pattern, and also Hub Centric... any idea if the wheel spacer that would be for a Scion TC be any different to a Vibe or Matrix? I know that the Scion TC's wheels work just fine on the Trix's and Vibes... any idea's?
August 2009 VOTM Click HERE for my Garage
Sublimewind
Re: Will Scion TC Wheel spacers work on Vibe/Matrix? (Kamikaze)
Post by Sublimewind »
Shouldn't be any difference, but I would worry about my wheel bearings... I know on Subies, about 5mm is as far as you want to go, without having to constantly worry about the WB's... 2cm is a LOT when you consider where the weight center would move in the loading of the WB..
Sublimewind
By the time you notice a problem with the spacers, the bearing will need replacing...
