hub centric rings
clp
hub centric rings
Post by clp »
If i buy custom 17 inch wheels do i have to have the hub centric rings or are they just an option?
CHRIS
Raven
Re: hub centric rings (clp)
Post by Raven »
You'll need the rings 99.9% of the time. They're only about $15.00 a set. I got mine from Discount Tire I believe. They are definately not an option, they're a necessity.
joholste
Re: hub centric rings (Raven)
Post by joholste »
i think if you buy wheels from tire rack.com they automaticalyy give you the rings for free
2003 Chevy Silverado Ext. Cab, Z71Formerly2003 Base Vibe (Frosty)
Jyik40
Post by Jyik40 »
Hubcentric rings are very important. If you don't use them, your wheels can be mounted off-center causing vibrations when you reach highway speeds.
RSTuningFactory
Re: (Jyik40)
Post by RSTuningFactory »
Quote, originally posted by Raven »You'll need the rings 99.9% of the time. They're only about $15.00 a set. I got mine from Discount Tire I believe. They are definately not an option, they're a necessity.I ordered one wheel from discount, they came with one set of 4 rings for free.
2003 Vibe GT.
hskater26
Re: (RSTuningFactory)
Post by hskater26 »
my wheels still shake with them and they are balanced correctly
-2003 Base Vibe-2002 Ducati ST2
darcmater
Re: (hskater26)
Post by darcmater »
so i was lookign at my papwerwork today on my rims and didn't notice a listing on it for hubcentric rings, so Iw ent down to my local discount tire where I got them from and the guy behind the counter said they have nominal use, but that I could get a set for like 15 bucks if I wanted. He made it seem as if they didn't make a naticeable differance. My steering wheel does vibrate a little at highway speeds, but for all I know that could just be from the wodner michigan highways. So should I get some, I mean its only 15 bucks or so?
Raven
Re: (darcmater)
Post by Raven »
If the hub of the wheel is a different size than the hub on the car then definately get them. The Vibe is made to be hubcentric not supported by the wheel studs.
Raven
Re: (hskater26)
Post by Raven »
Quote, originally posted by hskater26 »my wheels still shake with them and they are balanced correctly If that's the case you must have a tire with a bad belt or a bent wheel. Properly balanced and installed wheels don't shake.
WaveAction
Post by WaveAction »
most aftermarket rims should come with the hub ring..if not..then thats weird..
