Quote, originally posted by DavidPIL »Hiya Blanco,I would suggest going to a local automotive paint supplier and have them mix up the exact color for your car. Then use a paint sprayer called Preval
http://www.prevalspraygun.com/ to apply it. You should be able to get this at the paint supplier... I used this paint on my roof rail caps as well as a custom spoiler. It works well though creates a slight orange-peel effect. On such a small surface as the headlight covers, it won't be so noticeable.Since you'll be painting on ABS plastic, I would suggest using an adhesion promoter. You should be able to get this at the paint supplier as well, or at auto-zone. Read the instructions for this and make sure you follow. You should probably ask the paint place for what they recommend just in case they have a better idea.For me, a half pint of mixed Abyss enamel thinned for the preval sprayer cost about $14, the sprayer itself was less than $6 and the adhesion promoter was about $5. I used a standard etching primer for the spoiler and roof caps but they were pre-primed anyway. II'm thinking since these headlight covers are unprimed plastic, it might be best to use the adhesion promoter instead. You should sand the plastic to roughen up the surface a bit to help everything bond well.Hope this helps.DavePretty much EVERYTHING he just said. Also, for headlight baking, I can tell you from experience make sure you get the temps and times RIGHT!240 Deg BAKE (not broil!) at 4-6 min intervals. Check them every 4-6 mins! do not just leave them in there or they will bubble! Also, use a glass pan or dish to hold the lights, don't just place them on the bare metal grill in the oven (I would assume most people would probably figure this out, but just in case you don't).If you are worried about condensation and don't plan to change your headlights or your paint job is PERFECT, I will suggest using some high temp adhesive called "The Right Stuff". This is used on engines as a gasket sealer, so once you put this in the headlight to seal it, you won't be getting them apart again! It won't start breaking down til well over 400 deg! I have cleared and painted about 4 or 5 sets of headlights now. PITA, but once they are done, they're gorgeous!
