Bolts, bolts, and screws.Removing the visors are easy - there are screws at the base of the visor where it mounts to the roof - they don't even hide them.The seatbelts have a bolt on the B and C pillars if you pop off the plastic covering on them.I believe the plastic cargo panels are bolted down, and easily removed when you pull the designed-to-be-removed plastic pieces out.Basically, you should be set with a phillips screwdriver, a 10mm socket, and a 12 mm socket (not sure on this one).
