If it goes out then it may be a loose connection or a worn one. There is a thing called a Clock Spring inside the steering wheel that has the air bag contact points in it. As the wheel turns, these contacts remain in contact to deploy the air bag at any time. These clock springs do wear out at times and must be replaced. The best case in your situation is to have it checked out because it really could be anything. Good luck!
