New Poster, H.I.D./Xenon Questions
Zer0VIBE03
Post by Zer0VIBE03 »
Okay, so I bought my 03 Vibe about a week ago. Love it to death so far, easy on gas and insurance, stores all of my crap.I looked at the threads in here, but I can't seem to find it on my own. I want to eventually get H.I.D./Xenons and I tried searching on the web and ebay but can't seem to get any place that has prices and stuff other than "blinglightz" which I saw being made fun of in another thread. Where can I find a page online that actually has this stuff, for the Vibe, with prices and is a viable resource?P.S. if I am looking to modify anything by going through TRD, do I just basically shop for a 03 Matrix rather than an 03 Vibe?TYIA,Zer0.
2003 "Lava" Vibe
Tonyk27
Post by Tonyk27 »
For HIDs I have these and love them.http://item.express.ebay.com/X...sItem
WaveAction
Post by WaveAction »
welcome to the forums, im purchasing HID's off of http://www.thexenonstore.com/HID.php for $120 each kit
kevera
Re: New Poster, H.I.D./Xenon Questions (Zer0VIBE03)
Post by kevera »
I'd love HID's,but I won't disconnect my drl's.Too bad
WaveAction
personally i dont see why we'd have to disable the DRL's..HID use less power and stuff..and theirs a ton of cars out there that uses HID's all the time..such as cadillacs and acura
kevera
Re: (WaveAction)
Post by kevera »
If there was a way around it,I would get them.I seem to remember someone telling they had to be disabled,not totally sure on that though.
WaveAction
i guess we'll have to research, but alot of the higher up cars have HIDs as DRL's aswell, i personally dont see why we'd have to disable them, they use less power then a regular halogen bulb
keithvibe
Re: (WaveAction)
Post by keithvibe »
they do when they are at full power.... they require more power to start up. The drls only run at 80%. Because the drls are only running at 80% the ballasts don't have enough power to start.Thats why they strobe or flicker.
WaveAction
i see, so its best to disable the drl's? i dont see how the ballasts dont have enough power when they're supposed to be at 80%..what if you turned the actual headlights on when you start your car, so they can warm up and such..then turn them off..they would work properly after that??
Kamikaze
Re: (keithvibe)
Post by Kamikaze »
http://www.xenonrider.com has them bi-xenon too.
August 2009 VOTM Click HERE for my Garage
WaveAction
Re: (Kamikaze)
Quote, originally posted by Kamikaze »http://www.xenonrider.com has them bi-xenon too.seems kinda expensive for a bi-xenon kit..$260? http://www.thexenonstore.com has a bi-xenon kit which comes with everything for $175
WaveAction
found this on that xenonrider site kami posted up Quote »Will DRL (daytime running lights) or Auto-Switch-On effect the HID kit?For vehicles with DRL (daytime running lights) that use the same bulb for both DRL and low beam, you will need to deactivate your DRL. Most DRL operate on reduced wattage or fluctuating current levels. This will cause the HID ballast and bulb to flicker and burn out prematurely.
Zer0VIBE03
Recommended bulbs? 6000k or 9000k? I could live without the DRL's, I actually don't like that they are on when it's sunny out.
2003 "Lava" Vibe
WaveAction
6K or even 8K are the best way to go for headlights..im undecided on the HID's cause i dont wanna mess my warrenty up, brand new car so i'd hate to have something mess up and it not covered
Fastvibe03
Re: (WaveAction)
Post by Fastvibe03 »
I Zer0VIBE03, i sell HID since a year a half (see http://forums.genvibe.com/zerothread?id=32654 ) i started group buy a it close shortly. Be in if you want i place order 25 april. I have a H4 HID kit on my 03 Vibe and i didn't disable DRL and i don't have any problem. Thanks
Pontiac Vibe 2003 , neptune blue 72 000 Km - 17" Fast wheels Virus with 215/40ZR17 Kumho Ecsta Supra 712 tires for summer - 16" oem alloys wheels with 205/55R16 Nokian HAKKAPELIITTA 2 with eco stud system for winter - Tein S-Tech lowering springs (2.5" drop) - HID 6000K Bi-Xenon Flex - Innovatek IN-1044B 10.4" Roofmount Monitor with Built-In DVD Player for kids - Cosmo blue CAI
Mr. Joe
Re: (WaveAction)
Post by Mr. Joe »
Quote, originally posted by WaveAction »6K or even 8K are the best way to go for headlights..im undecided on the HID's cause i dont wanna mess my warrenty up, brand new car so i'd hate to have something mess up and it not coveredIt won't affect your warranty. You can do prety much anything, as long at it dosen't alter the function. I was pretty happy to find out that even something like a CAI and catback won't void warranty. Those items would not be covered under your cars warranty of course, but they won't void it. On the HID's... I am planning on getting these the price is nice, and I have talked to several people who have purchased them and have not had any troubles.As for disabling the DRL's, I don't think it is necessary. it will just be at full power all the time. I would really like to find a way to disable the DRL's without disabling the auto-headlamp system. In either case, the ballasts can handle an input voltage as low as 9 volts, and the DRL voltage should be approximately 9-11.5 volts. (Based on the idea that the DRl system powers the bulbs at approximately 80% of the standard voltage, and standard voltage is between 12 and 14.5 volts.) I plan on getting the 6000k system because the 8000k system tends to produce less visible light with the blue'er color. I considered the 4300k because they claim that it has the best light output, but I'm near 4100k with my SilverStar Ultras now and they still aren't nearly as good as my Vue's that are near 5000k with a similar rating in lumens.
2007 Frosty Pontiac Vibe, picked it up 6-01-071480 milesLife is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming..."WOW! What a ride!"
Whelan
Re: (Mr. Joe)
Post by Whelan »
1) my pictures are all over this site so I won't post them again.2) my kit is MUCH cheaper cause I own a Matrix, which utilizes a dual lighting system where two bulbs one for high and one for low work, instead of the Vibe that uses a single bulb with two filaments for both purposes. ($70)3) 6K equals a more white look, 8K is noticeably bluer. 4) Stock OEM HID kits are 4300K, the coloring is due to the projector lens type.5) Once you put them in, you will NEVER drive another car without them.
2012 GLI Autobahn 6MT
Fastvibe03
Re: (Whelan)
I agree with you Whelan.
