Amp fuse location
darcmater
Amp fuse location
Post by darcmater »
Well it has been a few weeks since I moved stuff around in the engine compartment and still haven't found a good location for the fuse block for the amps. At the moment it is attached to the top of the black bracket holding the battery down. I am wondering is it bad to have the fuse block for the amps right there? I might just leave it since its secured, easy to get to and not causing any issues atm
darcmater
Re: Amp fuse location (darcmater)
Post by darcmater »
/bump anyone have an opinion on this good/bad?
audiovibe
Post by audiovibe »
I think It should be ok there.Aron
Sublimewind
Post by Sublimewind »
You should be fine man, as long as it's not flopping around... shorter the better when it comes to placing the fuse holder next to the batter.. Streetwires even makes a battery terminal that carries a mini-ANL fuse holder right on it... The rule of thumb is no further than 18" from the battery..
