Drivers Side Floor Mat
bhb
Post by bhb »
I have the factory carpeted floor mats and the top portion under the clutch and brake pedal will not lay flat and curls up to the point of interfering with clutch pedal movement. Any else have this problem and how did you fix it other than replacing the mat?
NibCrom
Re: Drivers Side Floor Mat (bhb)
Post by NibCrom »
I know this isn't the answer you are looking for, but I have the rubber mats and they don't have that problem.I have had carpeted mats in my other cars, and I had the same problem you do.
CoolAKid
Re: Drivers Side Floor Mat (NibCrom)
Post by CoolAKid »
The all-weather rubber Vibe mats are the way to go...
"...don't concentrate on the finger, or you will miss all of that Heavenly Glory..."'06 Base Platinum Two-Tone. Automatic. Manual doors and windows. Old style factory crossbars AND GM Utility Bars. Old style center console lid. All-weather front floormats. Rear bumper fascia protector. Drawtite hitch.
Raven
Post by Raven »
Wash out the mat and lay it flat in that hot Hawaiian sun. Put some weight around the edges if you like. It should flatten out.
