Vibe Radio Compatibility
ilangsfs
Post by ilangsfs »
Can anyone tell me if the factory radio from the Vibe could also be used in an 01 Pontiac Aztek? The faces look almost identical. I'm at work otherwise I'd go check the plugs myself. Can anyone help?
Kamikaze
Re: Vibe Radio Compatibility (ilangsfs)
Post by Kamikaze »
Nice pic... where did you get it from?
August 2009 VOTM Click HERE for my Garage
ilangsfs
Re: Vibe Radio Compatibility (Kamikaze)
Post by ilangsfs »
My avatar? No clue. Somewhere on the net.
Kamikaze
Post by Kamikaze »
I just found it funny that I have the gif in my signature, and you have the same photo for the avatar...To answer your question, I'm not positive, but I believe that our radio is the same for all GM's, I believe that the wiring harness is the same... but being that so much of the rest of the car is toyota I guess I could be wrong... I haven't taken the factory radio out, so I'm not sure what the harness even looks like.
ragingfish
Post by ragingfish »
No, it won't work.Aztek has GM DataBus, requires the radio to be able to communicate with the rest of the vehicle and the BCM. The Vibe being primarily Toyota does not support GMDB.
2009 PONTIAC G8
WaveAction
Post by WaveAction »
i personally want the radio out of the newer pursuits or G6's..with the aux input..but according to the guy who works at mass, he said it wouldnt work..but i want to know if i were to hard wire it if it'll work..theirs gotta be something
