matching interior color
darcmater
Post by darcmater »
I was wondering If anyone had found a spray paint at the local autostores/superstores that comes close to the metalic silver interior trim of the vibe? I have been lookign around but hard to tell what ones will look the closest. Also can krylon fusion be used as a base coat to prime plastic pieces or is it best just to use normal plastic primer?
WaveAction
Post by WaveAction »
krylon fusion is awesome stuff for plastic..just get the krylon fusion primer and you're good. im not sure where or what the actual color is for the interior trim pieces
darcmater
Re: (WaveAction)
Post by darcmater »
Well this was the project, I think it turned out alright. Has allways bugged me how plain the passenger side dash wasand a close up shot
lovemyraffe
Post by lovemyraffe »
Looks great!
WaveAction
looks good, looks very similar to the silver of the other plastic pieces in the car
kmvibe
Re: (WaveAction)
Post by kmvibe »
Yes it is. What is the color you used?Kenny
darcmater
Re: (kmvibe)
Post by darcmater »
Its actually the combination of 2 colors. I was lookign for a metalic pewter like the s-10's had for a while, figured it might be the closest but couldn't seem to find any at my local auto part store. So I ended up gettign metalic silver and gun metal. I put down a few coats of the silver at first then very light mist of the gun metal to darken it up a bit and give it the dark little specs I see in the other trim pieces.
darcmater
Re: (darcmater)
Post by darcmater »
well I decided the color wasn't dark enough to match the trim as Iw anted so I messed around with the same colors and got somethign I think is more inline. Given the location of the handle I think I see why pontiac never did anything here, its just to dark to notice anyhting
