I have been looking for some routine maintenance parts, and a lot of the references distinguish between "2ZZ-GE" and 1ZZ-FE.I believe that 2ZZ-GE refers to the Vibe GT, but can anyone confirm this?Is there a note about whether 2ZZ-GE or 1ZZ-FE applies to my car in the owners manual or somewhere else in the car?Thanks!
Would you agree to debris acceptance? 2003 Vibe GTMods installed GM Top and Mid-Gate Spoilers, Cosmo CAI, TWM Short Shifter with Desert Eagle weighted shift knob, TWM Bronzoil Shifter Cable Bushings, Magnaflow Cat Back Exhaust, Unichip, Injen Billet Aluminum Engine/Sparkplug covers and oil cap, Optima RedTop Battery, Lineage Ground Wire KitAwaiting install: Energy Suspension Motor Mounts, DC Sports Header
I believe the 8th digit in the VIN is also the engine code........from there you should be able to identify your engine from info that's in the owner's manual.
