Mods for newer cars
rsaxman
Mods for newer cars
Post by rsaxman »
I just bought a '06 Base. I have been searching the forums and web for mods and it seems that a lot of what is our there is for older models (03-04), this includes intakes. Am I missing something? I know that Matix components can fit, but what about older years and GT components?Thanks
northvibe
Post by northvibe »
for the most part no GT parts wont fit, they are two different engines, well...wont fit with plug n play, some times modifications can be done, ie. intake, exhaust. imo not worth it unless its a enormous deal.06:-intake - cosmo makes one (needs to work with DBW)-exhaust - same, base for base06+ have dbw, so grounding the throttle body to the negative terminal on the battery is suppose to smooth some accel things out, ill be doing this to my ms3.-springs fit-sc just needs an adapter plate.Most all other mods fit from the 03+ era. It depends what you want though...what are you looking at for mods?
rsaxman
Re: (northvibe)
Post by rsaxman »
I figured I would start with an intake ( I had one on my Corolla) and also do some grounding work. Can you offer some suggestions? I thought I would go with the Cosmo CAI over the KN SR. Injen only seems to fit the GT.
northvibe
Post by northvibe »
Cosmo cai is good for 05+ vibes with dbw, its cheap and is pnp for those I had the TRD cai and mmmm cai ftw love the sound! here's a vid of the day I installed ithttp://videos.streetfire.net/v...5.htmGrounding kit and voltage stabalizer seem to help out as well, just like your corolla. Specially for the lights dimming when you roll the windows up/down.
rsaxman
Re: (northvibe)
Post by rsaxman »
Dumb question...what is DBW?
northvibe
Post by northvibe »
Drive by wire - where the throttle body is electronically controlled instead of by a cable attached to the gas pedal.
rsaxman
Re: (northvibe)
Post by rsaxman »
Thx, another question, is your throttle rotor the one for corollas?Thx for the help, sorry for so many questions.i found this one... http://weapon-r.com/english/in...=5971
02csnow
Re: (rsaxman)
Post by 02csnow »
There is also strut bar, front and rear sway bars, pulley sets, unichip, camcon, shocks, alignment kits, and bushings.There is more but the list can go on. Most of the Matrix parts will fit the Vibe.
Bye Bye Vibe.............
Raven
Re: (02csnow)
Post by Raven »
No Unichip for '05 and up.
northvibe
Re: (rsaxman)
Post by northvibe »
Quote, originally posted by rsaxman »Thx, another question, is your throttle rotor the one for corollas?Thx for the help, sorry for so many questions.i found this one... http://weapon-r.com/english/in...=5971 Hey no problem!! we are here to learn The throttle rotor I am selling is that same one from WR and can be used on all 1zz-fe engines that are drive by cable (not yours unfortunately).
rsaxman
Re: Mods for newer cars (rsaxman)
Post by rsaxman »
I cant seem to find alt. pulleys for '06 either.
1zzfe_808
Post by 1zzfe_808 »
all pulleys will work regardless of the year.
