Do your interior door handles let air in when driving? Weird
mjbsb69
Post by mjbsb69 »
When driving, I notice that the interior handles on my door panels let an outside air/draft leak or blow through them. It is the most noticable in winter months (feels very cold). Is there a fix for that problem?
zionzr2
Post by zionzr2 »
I have noticed this occur on many vehicles
ajflan
Re: Do your interior door handles let air in when driving? Weird (mjbsb69)
Post by ajflan »
Yeah mine does that as well. Just shove a sock there while you drive.
February 08' VOTM Check out my Band! http://www.facebook.com/pages/...67945
tribalman
Post by tribalman »
are you sure it's from the door? on mine i've noticed that air comes through the vents. i usually drive with the heat off and the fan off too. it doesn't matter if it's vents, by the feet, or on the windshield. it is more noticeable at higher speeds. if i can i put the control to vents and shut them. it helps.
None. Vibe is gone.
mjbsb69
Re: Do your interior door handles let air in when driving? Weird (tribalman)
Post by mjbsb69 »
Quote, originally posted by tribalman »are you sure it's from the door? on mine i've noticed that air comes through the vents. i usually drive with the heat off and the fan off too. it doesn't matter if it's vents, by the feet, or on the windshield. it is more noticeable at higher speeds. if i can i put the control to vents and shut them. it helps.I have the vent issue too. Putting setting on recirculation helps cut that down some, but the cold air leak I'm kind of concerned about really leaks in from the interior door handles....I know it sounds weird.
zionzr2
Post by zionzr2 »
If you want the air to stop coming through the vents as you drive at hwy speeds even with the HVAC off.... Hit the ReCirc button.
WaveAction
Post by WaveAction »
i've noticed it aswell, doesnt bother me but have noticed it..i gotta ask, has anyone ever tried to insulate their doors? similar to what you would do to a house but..not as toxic or something??
MRCN RCE
Post by MRCN RCE »
i don't think it would be possible to insulate the doors. you need the room in there to allow for wiring, and the movement of your windowsyou can put some sound dampening material in there, which i doubt would really insulate anything, but that's about as far as i think you could go.
GENVIBE: THE PLACE WHERE ALL THE COOL KIDS HANG OUT05 GTK&N SRI, exedy clutch, fidanza flywheel, Neo-GensLIFT: the equivalent of viagra for your tach n speedomy garagehttp://forums.genvibe.com/zerothread?id=24931
WaveAction
hmm well you can always have the wiring running ontop of the insulation..as for the window part..i'd just cut out where the window would be..like the access holes and such?
maple_flip
Post by maple_flip »
The wind leak from the doors is pretty much standard in all vibes. I have an 03 vibe and when i got my window smashed, the guy replacing the window couldnt get fully into the groves to reach the fallen glass at the bottom of the door. He indicated the small tiny holes at the bottom of the door which the glass will fall out of. There are 3-4 small holes down there. If you remove the door covering, you can get to it and plug it up if you like but there has to be a reason as to why they put those holes there in the first place. In any case, Good luck!
audiovibe
Post by audiovibe »
The holes at the bottom of the door are for drain purpouses when it rains or you wash the car and the water runs into the door. I have deadened my doors with a sound dampining mat which solves two problems, 1. It helped creare better midbass response for my speakers, 2. it stops the air from coming in thruogh the door handel.Aron
Vibe is gone and will be missed as I've gone country style
kunkstyle
Re: (audiovibe)
Post by kunkstyle »
Quote, originally posted by WaveAction »i've noticed it aswell, doesnt bother me but have noticed it..i gotta ask, has anyone ever tried to insulate their doors? similar to what you would do to a house but..not as toxic or something??Hehe. Sprayfoam. Although I take no responsibility for what happens after you try that one...
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
audiovibe
Re: (kunkstyle)
Post by audiovibe »
Quote, originally posted by kunkstyle »Hehe. Sprayfoam. Although I take no responsibility for what happens after you try that one... Cmon, ya know you should take the door off and use the industrial 2 part stuff, atleast then you can watch it grow.Aron
scott_h
Re: Do your interior door handles let air in when driving? Weird (ajflan)
Post by scott_h »
Quote, originally posted by ajflan »Just shove a sock there while you drive. Preferably not one you're wearing at the time. (especially if you don't want to take the sock off your foot!)
Scott
Envy03
Re: (audiovibe)
Post by Envy03 »
I have noticed recently while driving at high speeds that the driver side door is quite loud, wind noise, I am concerned that the "bumper" around the the door frame may be not firm enough. Any suggestions to help dampen that noise? Can you buy new "bumpers"?
bull77
Re: (Envy03)
Post by bull77 »
Quote, originally posted by Envy03 »I have noticed recently while driving at high speeds that the driver side door is quite loud, wind noise, I am concerned that the "bumper" around the the door frame may be not firm enough. Any suggestions to help dampen that noise? Can you buy new "bumpers"? i experienced the same issue, but on the drivers side. If the car is still under warranty, have the dealer look at it. In my case, I could pull the seal away from the door frame, they replaced it after attempting to reseal it.
