was looking to get a nice shine to match the exterior of the car paint job, found these links helpfulhttp://
www.ehow.com/how_218223....htmlhttp://w ... .htmlFirst attempt at this I scuffed up the surface of the covers with 800grit sand paper a bit. I then used automotive paint in a aerosolizer jar(not sure if thats an actual word but home you get my meaning) I put on 3 or 4 coats, can't remember for sure. I then applied the clear coat in another 3 or 4 layers. I then let thats et for a week to make sure everything had hardened. I then used 1000 grit sandpaper and wetsanded it, then switched up to 2000 grit. I then used some 3m buffing compound and a little 3inch buffer I found at the store to apply it. It turned out nice, good color and shine but because I was not thinking I didn't sand/buff the paint layer before applying the clear coat. This causes generally what is called "orange peal" which iof you look at the textured skin of an orange you will see why.So my second attempt I used 800grit sand paper to take the clear coat back off down to the paint, then switched to 1000 grit sandpaper and wet sanded that down to get rid of alot of the imperfections, then 2000 grit and wet sanded that to even a nicer smooth finish. I have removed most of the orange peal effect and what is there is much less noticeable. I then used the 3m buffign compound again and figured I would see if that would remove the rest of the imperfections of the paint. It did but not to the level I wanted( Iw ant the covers to match the paint perfectly) Now at this pount due to my inexperience in buffing and such some places in the paint seem a bit thin, so looks like I will try to add some more layers of paint and try again. Got to have a nice project to keep you busy I guess : ) If I were to do this again from scratch, I would have done 5-6 layers of paint just so when I sand/buff the paint itself there is soem good layers left, and probably the same amount of clear.
