Wipers won't go all the way down
eilros
Post by eilros »
The wipers on my wife's Grand Prix won't go all the way down. They work fine otherwise. Does anyone know how I would fix this issue? The picture below shows how the wipers sit when turned off.
2004 Satellite Base
kunkstyle
Re: Wipers won't go all the way down (eilros)
Post by kunkstyle »
What year GP? If I recall correctly, the 99ish models had kind of a notched nut holding the wipers in place, and you could adjust them accordingly. They could get stripped threw standard use, and may have locked in the position they are know. There may be a plastic cap to take off to get to the nut.
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
eilros
Re: Wipers won't go all the way down (kunkstyle)
Post by eilros »
It's a 2000 SE.
2004 Satellite Base
WaveAction
Post by WaveAction »
was it covered in snow/ice and she turned them on? you wouldnt know how many customers we get that have this problem cause they dont clean off their windshields properly and then strip or make the gear inside jump a notch or whatever
eilros
Re: (WaveAction)
Post by eilros »
Quote, originally posted by WaveAction »was it covered in snow/ice and she turned them on? you wouldnt know how many customers we get that have this problem cause they dont clean off their windshields properly and then strip or make the gear inside jump a notch or whateverIt happened this past summer so I don't believe there was anything putting pressure on the wipers.
2004 Satellite Base
ToolGuy
Post by ToolGuy »
The Park Stop Mechanism is not working/failed with the wipers. With some motors you can replace just it, it is an electronic control board others you need to replace the entire motor. I am not sure what yours has...
keithvibe
Cracked window... what do i do???fixed for ya!
Post by keithvibe »
First fix the windshield!then fix the wipers lol
melders
Re: Cracked window... what do i do???fixed for ya! (keithvibe)
Post by melders »
actually if you fix the windshield, the glass company will take the wipers off to do the glass, then they will put them back on in the correct location, saving you the hassle of doing that
2009 Pontiac Vibe GT - Jet Black Metallic
