windshield washer nozzle
melders
Post by melders »
how do you adjust the aim on those? i brought my car in for some body work after a tree crashed onto it, they repainted the hood, and now one of the streams doesn't aim exactly on the windshield...how do i adjust these?oh, and the car is ok, just about 15-20 dents, and a cracked windshield...but hey, all the stone chips in the hood are repainted
2009 Pontiac Vibe GT - Jet Black Metallic
Kamikaze
Re: windshield washer nozzle (melders)
Post by Kamikaze »
I had one on my civic that wouldn't work, ended up pulling it out, soaked it in hot water, then plugged it back in and blew air thru it. After that it worked fine... so if it's just not spraying like it should it could just be slightly clogged up.
August 2009 VOTM Click HERE for my Garage
Raven
Re: windshield washer nozzle (Kamikaze)
Post by Raven »
Just put a pin in the hole and adjust it that way.
melders
Post by melders »
its spraying...just not in the right spot...it is hitting just under where the wiper gets it on the driver side, its kinda wasting my fluid too, if its not doing anything.
Kamikaze
Post by Kamikaze »
hmmm...you could try: Quote, originally posted by Raven »Just put a pin in the hole and adjust it that way.If that doesn't work my next suggestion before buying a new one, is flipping your driver side and passenger ones to make sure it's the nozzle thats not right... I haven't looked too carefully at the Vibe's but I know there was basically no adjustability on my civic... they just snapped into place and that was it...
melders
Post by melders »
ok, ill try the pin first..i thought about swapping them, not sure how hard they come off...or i can have the body shop do it, since its not right :D
Sublimewind
Post by Sublimewind »
While you are at it, aimr the center ones high enough to go over the roof, used for annoying tailgaters...
melders
Re: (Sublimewind)
Post by melders »
lol...nice one that is a good idea!
Kamikaze
Re: (melders)
Post by Kamikaze »
From what I remember they basically just squeeze together from the under hood, and pop out... (it's a little harder than it sounds) it took me a little bit to get it.. but I took my time cause I didn't want to scratch the car... also, since the car was 10 years old the hose that attaches to the nozzle didn't want to come apart to easily so I really had to tug...sorry, I don't have any pics, otherwise I'd try to show you in a tutorial...
melders
Re: (Kamikaze)
Post by melders »
Thanks alot...it at least gives me an idea. if someone else has any other ideas, please let me know
Sublimewind
I "think" you can buy aiming tools... I don't know though..
melders
Re: (Sublimewind)
Post by melders »
hmm..ok, ill try the pin first. what about a paperclip?
Kamikaze
Re: (melders)
Post by Kamikaze »
You could try, but it might be too thick, the nozzle has a pretty small hole.I had tried using a needle (for thread) but my problem was more in the actual nozzle, where I had to run the warm water, then blow air thru it...
melders
Re: (Kamikaze)
Post by melders »
it seems like i have to take it off...how do i get it off??? under the hood, the nozzle is under a piece of metal, i didnt play with it much, to cold, but it seems like it would be nearly imposible to get the thing off..help!
Kamikaze
Re: (melders)
Post by Kamikaze »
sorry man, I should have looked at this earlier.. I had my car in the shop afterwork, and could have easily looked to see what's up with the nozzle... I'm at work now.. but if no one has ideas later, I can probably take a look at it when I get home. and let you know... I'll check back later today to see if anyone was able to help...
melders
Re: (Kamikaze)
Post by melders »
thanks kamakaze...i did get it though, the pin worked, and it also cleaned out the nozzle, its aimed the way it needs to be
Kamikaze
Re: (melders)
Post by Kamikaze »
Glad to hear it! I forgot to take pics last night... it was too cold, and I started playing Forza II... and bam it was time to go to bed!
tribalman
Re: (Kamikaze)
Post by tribalman »
i'm having an issue with mine too. the driver's side isn't spraying all the time. might just be too cold and the line is getting plugged by being frozen. might try to take it out and clean it. also, how does one get the head shield off so i can get access to the line and the sprayer? i've already ripped it a bit trying to get it off once before.
None. Vibe is gone.
Kamikaze
Re: (tribalman)
Post by Kamikaze »
Quote, originally posted by tribalman »i'm having an issue with mine too. the driver's side isn't spraying all the time. might just be too cold and the line is getting plugged by being frozen. might try to take it out and clean it. also, how does one get the head shield off so i can get access to the line and the sprayer? i've already ripped it a bit trying to get it off once before.Anybody with some helpful hints? I haven't done this yet (haven't had to, haven't had time to look at it) If I get bored this weekend I'll probably look into it.
melders
Re: (tribalman)
Post by melders »
If its plugged...i just used a pin, and it worked..i even applied some force, and it adjusted it.
Kamikaze
Re: (melders)
Post by Kamikaze »
I looked at the plastic pins that hold the mat on the hood (the fabric cover)These pins are a real pain to take off! I broke one trying and decided not to mess with it. I had a tool that has a prong on either side that slides under the pin to pry it up, but what happens is the pins have a ridge in them to keep them in place. So when you pry on it you pretty much break one of the little tabs.If you plan on taking that cover off, my suggestion would be to get some new pins right away if you plan on putting the cover back on...Or try to get the right tool that would allow you to take the pins out without breaking them.. Sorry no pics, but it was a no-go for me.
bphurl
Post by bphurl »
These nozzles are not adjustable. They can be easily removed by forcing a credit card between the hood and the rubber gasket. You can see the locking tabs in the attached photo. They cost about $35.00 CDN each so it is worth removing them and trying to clean them.
Re: (Sublimewind)
.............used for annoying tailgaters...........Hey, that's the excuse I give cops when pulled over for tailgating.........."officer, I was only trying to catch up to the car in front of me to take advantage of the free car wash"
vibolista
Re: windshield washer nozzle (bphurl)
Post by vibolista »
If the nozzle isn't adjustable, then how did melders adjust his? Was the nozzle sprayer possibly partially blocked by something that caused it to hit the top of the windshield? It's way too cold to go out and investigate this right now.
Re: windshield washer nozzle (vibolista)
The rubber grommet can get worn and sit funny, or you can add/trim/shim to get the desired spray path!
