How To: Rear Wiper Replacement
pmarte
Post by pmarte »
Clearly one can see that this blade needs replacementI used Toyota part #85214-12310Pull the wiper arm away from the car and rotate the blade outwardPull the blade assembly to the left. The blade is held by tension.To get the rubber wiper out, carefully bend it about 1.5 inches from the end until it clears the retainerThe rubber is now free to slide outThere are two 'backbones' that need to be re-used with the new rubber bladeThe replacement has grooves on each side to receive the 'backbones'Slide the rubber blade back into assemblyGently bend it to get it back in. Take care not to tweak the backbonesHere the wiper is snapped back onto the armMy index finger points to the tensioner/detent that holds the wiper in position. Give it a little push to assist the reassemblyAll done!
WaveAction
Post by WaveAction »
good write up, but you shoulda put it in the "tech how-to and do it yourself" thread..but one of the mods will move it, just saying for future posts. i never really knew how to change it, i figured you'd change the whole thing and not just the rubber blade it self
pmarte
Re: (WaveAction)
Post by pmarte »
I put it here to check out the post and do some editing, I will move it to How To soon
Sublimewind
Post by Sublimewind »
Hmmm... you found the proper sized replacement insert... I had to buy one double the length and cut it..
zionzr2
Post by zionzr2 »
also already have a write up here:http://forums.genvibe.com/zerothread?id=7733
Magus_Taliesin
Post by Magus_Taliesin »
Just changed entire assembly, got the part online for $15.00 and took about 30sec to change.
Raven
Re: (Magus_Taliesin)
Post by Raven »
The rubber insert is about $3.00 at a Toyota dealer and takes 10 minutes to change.
zionzr2
Re: (Raven)
Post by zionzr2 »
Quote, originally posted by Raven »The rubber insert is about $3.00 at a Toyota dealer and takes 10 minutes to change.It shouldnt take that long the next time. It takes me much closer to the 30 sec. when i change just the insert.It is also not necessary to revove the blade asymbly from the vehicle.
PopeyeFAFL
Post by PopeyeFAFL »
You guy's are genius.So following the instructions of this site, I just replace the insert of the rear wiper of my Vibe 2005.Here the breakdown (all Canadian Prices, roughly 1$ (CDN) = 1$ (US), those days).Replacement blade unit from GM dealership: 25.15$+tax = 28.39$Replacement blade unit from Toyota dealership: 10.65$+12.02$ (not in stock)Replacement insert (qty 1) from Toyota dealership: 4.20$+tax = 4.74$So I just replace the insert, took me 5 minutes, real easy, worth it.Thanks again for your knowledge.
