i was just wondering how much it would cost to replace an entire door on a pontiac vibe....saw this commercial where a guy had his car door ripped off in a car wash cuz he opened it to get a flyer on his windshieldany ideas...im guess a couple thousand$i know totally random right?
you can get an entire door shell, but you'd still have to order every single item that goes into it seperately..... I'd estimate $2,500 in parts, and probably $1,800 in labor to build it, paint it, mount it ect. Most times an entire door has to be replaced, they like to use salvage yard doors, they might have to repaint, but it saves having to build the thing from scratch.
Quote, originally posted by tnpartsguy »you can get an entire door shell, but you'd still have to order every single item that goes into it seperately..... I'd estimate $2,500 in parts, and probably $1,800 in labor to build it, paint it, mount it ect. Most times an entire door has to be replaced, they like to use salvage yard doors, they might have to repaint, but it saves having to build the thing from scratch.so if you still had all the parts all you would need is the door shell, paint, and the cost of the labor im guessing $3,000? lol
wellll i didnt make up the commercial cuz i really saw a commerical on tv like that...hahahhahahah.....something did happen to the vibe.....ill just let you know that it still closes and its just that its raised a little so the weather strip doesnt seal properly....my dads taking it for an estimate tomorrow while im at work.....after the estimate and maybe after its fixed ill have a story to tell...
anybody ever hear of econofix?...i sent an email worded as this....Pontiac VibeRepairs: driver front door bent backward when going reverse....does not close properly..needs to be replaced due to bent and cracked door....rear view mirror and interior components of door do not need replacementYear: 2007their reply was ..."Approx.$500-$750" rigggggght?....i wish...well ill find out tomorrow i suppose...im hoping its not above $3000 or it will put off me paying off the vibe awhile longers...
Quote, originally posted by waveresponder »Pontiac VibeRepairs: driver front door bent backward when going reverse....does not close properly..needs to be replaced due to bent and cracked door....rear view mirror and interior components of door do not need replacementYear: 2007their reply was ..."Approx.$500-$750" A few years ago, the passenger door on my Dodge Intrepid was bent completely forward from being hit by another car while the door was being opened. Door didn't have to be replaced, but it had a nice crease and also a crease in the fender. IIRC, $1500 or so...So, what I'm gettin at is that $500-750 seems to be pretty low, possibly not right.
$1,775.00 give or take a few hundred dollars is the estimate....the only problem is that it cant be dont to the 25th and they need it for a few days....
