does anyone have greddy exhaust for the base model?
kylethakillah
Post by kylethakillah »
I have herd several different things about it not fitting the base model but i want to know for sure before I rule it out.I basically want to know if it fit without fabrication.thanks, Kyle
silver 2005 Base18" KONIG Runaways K&N typhoon air intake
ajflan
Re: does anyone have greddy exhaust for the base model? (kylethakillah)
Post by ajflan »
Nope. The exhaust on the gt and base are different.
February 08' VOTM Check out my Band! http://www.facebook.com/pages/...67945
kylethakillah
thank you for helping me out man im not only new to the vibe but im new to cars in general.. haha its pretty badwhat exhaust would you recomend?
kylethakillah
ok nvr mind i read the other post thanks
ajflan
Post by ajflan »
Magnaflow makes the only true catback system for our cars. Everything else is only axle-back. For a cat-back, I would recomend Magnaflow.
kylethakillah
Re: (ajflan)
Ive actually herd a lot about magnaflow.. I'm gonna do a little more research but I'm thinking thats the way to go.thanks again
kylethakillah
the magnaflow is close to 600$ and the last time i checked the Borla was on sale for close to 300$do you think the magnaflow is worth the extra 300$?
DA1ANDONLY
Post by DA1ANDONLY »
if you remove the resinator car sounds so much better and it gives it a nice tone i did it to my car
Petrucci914
Re: (kylethakillah)
Post by Petrucci914 »
You can get the Magnaflow for $300-400. Check out neverenoughauto.com
ramenboy...
Re: (kylethakillah)
Post by ramenboy... »
the borla exhaust was recently discontinued. you might be able to find one for less than $300. but the the key word here is 'find.'good luck!
de-badged o4 vibe
o2 triumph speed four
drunkenmaxx
Post by drunkenmaxx »
don't be afraid to go custom either man. i got my custom exhaust done for less than $400 total. (see my signiature)
ajflan
Post by ajflan »
Good point, custom is a great way to go. Also, remember that Borla is only an axle-back system.
Herb
Re: (Petrucci914)
Post by Herb »
Quote, originally posted by Petrucci914 »You can get the Magnaflow for $300-400. Check out neverenoughauto.comI'm seeing $390 listed from themhttp://neverenoughauto.com/ind...=1687Also free shipping in US
drunkenmaxx
one must also note that this guy (like me) probably won't have the savvy to install the system himself, which will cost an additional amount.
Herb
Re: (drunkenmaxx)
Post by Herb »
Quote, originally posted by drunkenmaxx »one must also note that this guy (like me) probably won't have the savvy to install the system himself, which will cost an additional amount.I don't think it was that bad, though I did mess up up the cutting part by just a little bit.http://forums.genvibe.com/zerothread?id=29385Also I was missing a hanger from running over a rubber wheel chock a few years back didn't help the alignment. However, once I got the replacement hanger I took it to a shop to get it welded so I wouldn't have to worry about the clamp. The weld job was $50 and the guy at the shop helped me line things up which didn't take much.I think it's a good weekend afternoon project with a buddy.
kylethakillah
thank you guys for helping me out.. your right most of the stuff I cant even begin to install my self. But luckily The guy at our local auto shop does lol
WaveAction
Post by WaveAction »
i thought someone here had the Greddy exhaust? or atleast the muffler section of ithttp://forums.genvibe.com/zerothread?id=31511
WagonMafia
Re: (WaveAction)
Post by WagonMafia »
Yea I have the Greddy exhaust but it's just the axle-back kit but thats all they make. I have a GT though, if Kyle wants the greddy exhaust I would go with the Greddy Dynamic Tune Kit it has Two outlets from the muffler and you can plug one up to give it a higher or lower exhaust note deppending on your preferance. If thats what you would like to go with check out the greddy website, and find the outlet section. There only a 100 bucks because there discontinuing them, so i would jump on it quick. Then with your K&N CAI, PPE Headers, Magnaflow Hi-Flow Cat, and a resonater delete your vibe is gonna sound nice. If they dont have any more though just go with a Invidia, Tanabe, Skunk2, or Greddy Evo 2 if thats the way you wanna go for the import exhausts, these are for the 2zzge though. They'll fit but all you have to do is change the flange
kylethakillah
where can you find a flange? and how hard is it to change the it?
WagonMafia
Re: (kylethakillah)
You could probably just take it to a shop and by the flange there, like midas or some local shop.
kylethakillah
the only problem is I live in a very very redneck town in the middle of nowhere so I would have to order it from somewhere or go at least 50-60 miles out of the way to get one
WagonMafia
Re: (kylethakillah)
You can use your stock exhaust and weld it to the new one. Are there any local shops that would be able to do it for you. I say go custom it would be the same as buying the kit, and if you have enough confidence do it yourself. All you need is a tig welder, a sawsall, and the neccesary tools to install the exhaust.
kylethakillah
im really thinking about that. just cutting the flange off the new pipe and replacing it with the one from the original pipe.
DA1ANDONLY
Re: (kylethakillah)
sorry wagonmafia but those import exhausts are not just for 2zzge..evo2 exhaust are usually for turbo cars..that guy can pretty much get any exhaust..but if he does want it to sound nice..he might have to go custom..by the way wagonmafia what greddy exhaust do you have?
WagonMafia
Re: (DA1ANDONLY)
I have the Evo2, and there not usually for turbo cars but they do have kits for turbo cars to. Your probably thinking of the EvoTT those kits are for Turbo cars only because they have larger piping to optimize performance in its boosted form. I told kyle that those kits i mentioned were for the 2zzge not the 1zzge. I know they make them for other cars to.
DA1ANDONLY
Re: (kylethakillah)
well look around online.. evo2 were meant for turbo cars...thats why when i was listening to ur exhaust vids..i notice your exhaust was loud towards the end...gurantee if you get a new exhasut ur car would sound so much better...not saying nothing wrong with ur exhaust. but evo2 not meant for cars that do not have turbos.
WagonMafia
Re: (DA1ANDONLY)
My exhaust was loud at the end of the gear because of lift, not because my exhaust was meant for turbo'd cars. Go take a look at the greddy website.
DA1ANDONLY
Re: (kylethakillah)
i know its the lift that makes it loud.. what im trying to say is that ur exhaust gets loud when is at high rpm...i bet when ur driving normal it does not sound loud like it does at the end..when u have a constant sound from begining to end thats a normal exhaust..ur exhaust sounds loud when is at high rpms and when lift kicks.
WagonMafia
Re: (DA1ANDONLY)
It does sound the same through 1k to 6k then lift kicks in. Thats the only time its louder. Plus that video sucked cuz i used a phone, in person its a lot different.
kylethakillah
Re: (WagonMafia)
so do you think it would work on the base if I replaced the flange? oh and does ne one know if the hangers on the base and gt are the same?
DA1ANDONLY
Re: (kylethakillah)
that is not a phone you used because it would not sound like that it would sound ugly if u used the phone... well see what you can do man i really want to hear that exhaust..i dont know if i want to keep my borla or not
kylethakillah
Re: (DA1ANDONLY)
whats wrong with your borla? does it sound good?
DA1ANDONLY
Re: (DA1ANDONLY)
borla sounds lovely...but im always willing to try different things on my car ..but i want to hear how a greddy sounds im waiting on wagonmafia to get a new video so i can listen to it.
kylethakillah
has ne one herd about the skunk2? any sound clips?
WagonMafia
Re: (DA1ANDONLY)
Here you sorry it took so long I've been real busy with work.
kylethakillah
its ok. I finally got my intake on so exhaust comes next =]still trying to decide
