Clunking sound when accerating.
ProtonXX
Post by ProtonXX »
If I do a quick acceration at low speed (0-20. I hear a clunking sound coming from the right front side of the car. There no other sound when turning & haven't had other problems. Any idea what this can be.? Im leaning on a bad CV joint maybe
Raven
Re: Clunking sound when accerating. (ProtonXX)
Post by Raven »
A bad CV will usually make a clicking noise if you turn the steering wheel full lock in the direction of the CV in question and drive very slowly.
slowpro
Post by slowpro »
My wagon clunks during certain "spirited Driving" manuevers. Lowered suspension+ stock swaybar = clunk. dunno if same holds true for the vibe.
WAGON LUST 2002 Protege5
JustinVGT
Post by JustinVGT »
It could be something as simple as your wheel lug nuts. If they are not tightened to spec, you can experience an odd clunking sound. That happened to be my case a couple years ago.
northvibe
Re: (slowpro)
Post by northvibe »
Quote, originally posted by slowpro »My wagon clunks during certain "spirited Driving" manuevers. Lowered suspension+ stock swaybar = clunk. dunno if same holds true for the vibe. yup mine does that after I lowered it. Its usually just the spring isnt seated properly and well im too lazy to take it off and redo it again.could be some linkage, or ball joint. did you try when the car is parked to just push down on the corners of the front?
JohnC
Post by JohnC »
My guess would be...1st motor mount(s)2nd CV joints. Usually CVs will clunk at shift points and while turning, especially when going up a driveway or inclined surface.Both are pretty easy to check.
ProtonXX
Re: Clunking sound when accerating. (JohnC)
Post by ProtonXX »
Doesn't matter if Im turning or not.Usually the sound only comes from 1st gear & max acceleration.
