Tools:Jack2 Jack stands19mm socketBreaker barJack up rear end of car and support with jack stands. there will be plenty of room to work with on most stands lowest settingthen using breaker bar with 19mm socket loosen the top nut for each side. it will require lots of strength even with a 30" bar. i prefer to push my foot against the tires cause im horrified ill pull the car right off the stands (even though i somehow doubt it will ever happen)once loosened they come off quite easily. take note the direction of the sway bar, you will see the spacing of the bar is offset, the longer side faces down, making the bar closer to the top of the frame. (seen in picture 2)this guide was written because Never Enough auto asked for pictures once project was completed. they are free to use this info in anyway for their site.
