Hi,I just got an 08 Vibe with automatic trans and would like to add OEM or OEM style cruise control.Anyone got any suggestions which brand to buy and where to get it?Thanks,Joe
All you need to buy is the control stalk since the necessary control and sensors are already in the car. Here's one source for the control stalk:http://www.rockauto.com/catalo...,4320You'll also need to cut a hole in the plastic housing around the steering column and reposition the green ground wire for the horn which uses the same connector. That wire has to be removed from the existing connector and inserted into the new connector that comes with the stalk.As mentioned, there are lots of previous threads with more detailed instructions. A very worthwhile and pretty inexpensive modification.
It's not difficult, and well worth the effort. I used a one inch wood cutting bit to cut through the plastic steering column. It made a nice clean cut, and it looks like it came from the factory that way.
"Don't look to the government to solve your problems, the government is the problem." Ronald Reagan"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." Ben Franklin.
