Magic 8-ball says, "Outlook does not look good."Quote, originally posted by keithvibe »a bit more info please... auto, gt?It can't be a GT - it's an automatic transmission code. I'm going out on a limb and saying base Vibe w/ auto tranny here (could be AWD).Are there corresponding transmission shift problems? Since it's electrical, it is likely the ECM/PCM (big bucks), but the good news is that at least Toyota issued a TSB for this.
http://www.matrixowners.com/tsb/T-TC014-06.pdfThe bad news is that TSBs don't fall under the category of recall (which would require replacing regardless of warranty status).The good news may be that it is likely covered under the powertrain warranty which should still be intact. Specifically if it is a transmission problem, its a powertrain problem.Overall, unfortunately this one is for the dealership to sort out but I'll cross my fingers that it is covered. If the dealership denies it on warranty, you may take a chance and pick one up at Pam's Auto (here's one for a 2005 base, automatic, w/ antilock brakes
http://www.pamsauto.com/p-2525....aspx). At $175 plus shipping, that's cheaper than you will find at the dealership.However, I'd wait to buy it until dealership tells you it is the PCM. It could be a solenoid replacement...
