I need help figuring out a part number for this push-in-retainer clip. I think that is what it is called. If you can see the attached picture you will notice that the pieces on the back are broken.
I don't know the exact part number, however Checker and Autozone have similar ones in their bolts/screws area. They are marked as plastic rivets (or something like that) and are also marked as GM. They are not exactly the same, but they work the same and fit. I ended up replacing all of mine over time with them and never had an issue.
I think the GM part # is 88970767.I had to replace a few of those myself and ended up using OEM front grille retainer clips (part #94853733) since I had an extra bag of them. They don't hold as tight as the original retainers, but they do the job.
