Does anyone know the stock speaker wattage?
SalsaVibe2003
Post by SalsaVibe2003 »
I just installed a new Alpine head unit in my 03 Vibe. Everything is working, save the popping noise that is heard whenever i change tracks and the fact that the volume at 5 is the loudest i would go. I know that line level converters would solve the second issue, but i was toying with the idea of an aftermarket amplifier. So i was wondering if anyone knew the wattage of the stock speakers, in case there was any possibility that i could get away without replacing them. Thanks guys!
Jahntassa
Post by Jahntassa »
If you aren't using the M&T system, probably RMS of around 12 watts, maybe peak of 23w.If you're using the M&T system, I have no idea, but you'd need to get an amplifier capable of driving six speakers at 2 Ohms. The tweeters have a crossover built into the factory amp. (Or you'd need a four channel with crossovers for the tweeters).The stock speakers on M&T are probably around 23w RMS @ 2 Ohms, guessing 50w Peak.This is all assumption though.
SalsaVibe2003
briantforce
Post by briantforce »
I just changed out the speakers in my 2003 gt wtih the 4 speaker system and the stock were 17.5w peak
- Brian T Force2003 Vibe GTBlack with gray lower pannelling, 17" alloysPoineer DEH-P6900ub Head UnitSony Xplod 4way / Poineer ts-a1682r 4wayMTX Thunder 4500-4510-04Blaupunkt tha475always 93, always synthetic
Sublimewind
Post by Sublimewind »
Yeah, without knowing what stock system you have it's hard to say... If you are using the factory amped system, it's best to bypass when changing things... If it's a non-amped system, then there shouldn't be an issue...
Raven
Re: (Sublimewind)
Post by Raven »
Wow a 1 year timewarp response time.
