Shimmy/Wobble above 50mph
Whelan
Post by Whelan »
Well I did the donuts last night in the snow it was fun. But today driving to work I noticed the car shaking at 50+, then at 60+ it was much worse. Anything below 50 you feel nothing and the car drives fine.-checked torque settings on wheels, all is good.-alignment is still fine, car does not pull-quick undercarriage inspection did not reveal anything broken or out of place.-engine runs fine, no sign of issues or noise.I am thinking it is my wheel balance. Could this be knocked off by doing those little donuts in the snow? It's the only conclusion I can come up with, but I just want to know if it's possible to mess up your wheel balancing by doing. Under 50 it's unnoticeable which is why I believe this.
2012 GLI Autobahn 6MT
Sublimewind
Post by Sublimewind »
See my post in your Video thread.... You has much to learn, young grasshoppa..
prathman
Re: Shimmy/Wobble above 50mph (Whelan)
Post by prathman »
Quote, originally posted by Whelan »I am thinking it is my wheel balance. Could this be knocked off by doing those little donuts in the snow? It's the only conclusion I can come up with, but I just want to know if it's possible to mess up your wheel balancing by doing. Under 50 it's unnoticeable which is why I believe this.It can certainly be way off just from a little snow and ice that got jammed into the inside of the wheel as you slide sideways. Also possible, but much less likely, is that a balancing weight got knocked off one of your rims.
kevera
Re: (joatmon)
Post by kevera »
ahahahaha,
AKLGT
Re: Shimmy/Wobble above 50mph (prathman)
Post by AKLGT »
Quote, originally posted by prathman »It can certainly be way off just from a little snow and ice that got jammed into the inside of the wheel as you slide sideways. Also possible, but much less likely, is that a balancing weight got knocked off one of your rims.+1
AKLGT1998 Subaru 2.5RS
Mavrik
Re: Shimmy/Wobble above 50mph (AKLGT)
Post by Mavrik »
+2 on snow built up inside your rims.
zionzr2
Re: Shimmy/Wobble above 50mph (Mavrik)
Post by zionzr2 »
Quote, originally posted by Mavrik »+2 on snow built up inside your rims.+3
keithvibe
Post by keithvibe »
the detail god forgot to detail all the snow out of his wheels..... I would ask for my money back
Whelan
Re: Shimmy/Wobble above 50mph (keithvibe)
Post by Whelan »
Haha, I posted responses in the off topic thread with my video.I must say I have never owned a set of wheels and attempted this. I always had steelies with hubcaps so I guess the snow/ice never got packed. Not to mention I've never really done that kinda play in the snow.
Mavrik
Post by Mavrik »
but as your sliding sideways, snow gets in from behind... with steel wheels and hubcaps, the snow has nowhere to go but build up.
