New Engine Installed Yay!
ProtonXX
Post by ProtonXX »
But 2 CEL Error Codes. Boo!P1656& P0325Anyone know exactly where the Knock sensor is at on 1ZZ? Im hoping its not under the air intake manifold
Raven
Re: New Engine Installed Yay! (ProtonXX)
Post by Raven »
If you don't mind me asking, what was the total cost of replacement?Most Japanese engines are pretty sane as far as knock sensor location but I don't know where it is on a 1ZZ. On my Subaru it's right on top of the engine at the back in plain view. My GMC requires removal of the intake manifold as you mentioned. It's also in a low spot which fills with water if you wash your engine and the connector corrodes and gives a CEL.
ProtonXX
Re: New Engine Installed Yay! (Raven)
Post by ProtonXX »
$1100 for engine$100 for water pump (just in case)$30 for thermostat i think (just in case)$15 for locktight (for torque convertor and flywheel)$100 ($35 a day for 3 days for mhobby shop bay & tool rental)$105 for broken OCV Valve (P1656 Error)$40 for antifreeze, trans fluid & Oil & Power steering fluid (we took the power steering hoses off by accident.
Raven
Post by Raven »
DIY Well done.
keithvibe
Post by keithvibe »
Quote, originally posted by ProtonXX »Anyone know exactly where the Knock sensor is at on 1ZZ? Im hoping its not under the air intake manifold Yes it is...
damronjr
Post by damronjr »
Welcome to the DIY Vibe Engine Replacement Club! Lots of fun, huh?!? I managed to get away without any CELs when I did mine. Good luck ripping that IM off again!
ProtonXX
Re: New Engine Installed Yay! (damronjr)
Post by ProtonXX »
fixed. the screw was loose & I tightened it. No more CELs
ProtonXX
Post by ProtonXX »
fixed. the screw was loose & I tightened it. No more CELsPics are herehttp://www.clan-lone.com/forum...t=736
Petrucci914
Post by Petrucci914 »
Why did you have to replace your engine?
2003 Pontiac Vibe Base - AutomaticTRD Supercharger w/ Smoothflow PulleyaFe Drop-in Filter - DC Sports HeaderFull 2.25" Exhaust -Magnaflow Catback + CatsOptima RedTop - Tru-Cool Tranny Cooler
damronjr
Re: New Engine Installed Yay! (Petrucci914)
Post by damronjr »
Quote, originally posted by Petrucci914 »Why did you have to replace your engine?I'm guessing it has something to do with this:http://forums.genvibe.com/zerothread?id=31207
ProtonXX
Post by ProtonXX »
Quote, originally posted by damronjr »I'm guessing it has something to do with this:http://forums.genvibe.com/zerothread?id=31207Yep thats the old one
keithvibe
Post by keithvibe »
Quote, originally posted by ProtonXX »fixed. the screw was loose & I tightened it. No more CELsdid you have to take the manny off or did you get in there some how?
ProtonXX
Re: New Engine Installed Yay! (keithvibe)
Post by ProtonXX »
Transmission stayed in. We had to unscrew the torque converter thru the starter hole & the hole on the bottom (its covered by a brake show shaped piece of plastic.). Looking back leaving the transmission in made things easier because all the extra wires and stuff sat on that side anyway.
damronjr
Post by damronjr »
Quote, originally posted by ProtonXX »Transmission stayed in. We had to unscrew the torque converter thru the starter hole & the hole on the bottom (its covered by a brake show shaped piece of plastic.). Looking back leaving the transmission in made things easier because all the extra wires and stuff sat on that side anyway.I left mine in as well, but others have said it is easier to remove the whole thing. With no experience going that route, all I can say is to each his own, but to me it seems simpler to leave the tranny in.
