I remember at a rally seeing a GVC member with his OBD on a PDA and another connected to a laptop. I can't find anything specifically on these members, but I found these threads for you that may help a little.http://forums.genvibe.com/zerothread?id ... ad?id=4148
Thank you, that was interesting to read, but I was just curious if anybody knows/uses a bluetooth (BT) interface to make diagnostic tool wireless. That is, some adapter with BT would be connected to the OBD2 connector, and you can use a PDA or a laptop equipped with BT wirelessly. This setup would be very convenient especially if you have 2 cars since to switch between cars would be a snap, you don't need to route a cable...
Digimoto offers a bluetooth OBDII solution. I would use a USB connection because of the hard connection and the lack of interference with my cell phone's bluetooth headset.There are pros and cons listed on http://www.mp3car.com - just check their forums out and search for bluetooth under engine diagnostics and obd.
