Garage Door Opener Button
Cajun
Post by Cajun »
I found a use for the left side compartment. I installed a black push button (Radio Shack) in one of the blank spaces above the compartment. I wired from it to a garage door opener stored in the compartment. It looks like it belongs (more or less) and is a lot easier trying to remember which of the many compartments I stored the opener.I can post a picture if you are interested.
NSimkins
Global Moderator
Re: Garage Door Opener Button (Cajun)
Post by NSimkins »
quote:I can post a picture if you are interested.Please do. It would be appreciated.
Cajun
Re: Garage Door Opener Button (NSimkins)
Post by Cajun »
This is a radio shack button which cost about $2.50. You have to open your garage door opener and solder the button wires across the appropiate spot on your opener. You can test which but placing a wire across the suspected points. If the door moves, it is the right ones. Try not to have your car under the door during this operation.
Sub-Vibe-R
Post by Sub-Vibe-R »
It could be a good idea to "tie wrap" the remote under the dash. This will avoid some rattles and give you back the compartment.
NovaResource
Post by NovaResource »
Nice job, Cajun.
KSNeptune
Re: Garage Door Opener Button (Sub-Vibe-R)
Post by KSNeptune »
I agree tucking the remote behind the dash would be better. But remember you occasionally have to replace batteries in those remotes, so keeping it in the flip-open compartment is probably gonna prove the easiest. And I know radio shack has lots of switch styles. It would be nice to find a useable switch that looks "factory", and simply replaces the whole panel opening.KSNeptune
Herb
Re: Garage Door Opener Button (KSNeptune)
Post by Herb »
Well how about relocating the battery to a more accessable location. That way the remote can be permanently stowed away.
Would you agree to debris acceptance? 2003 Vibe GTMods installed GM Top and Mid-Gate Spoilers, Cosmo CAI, TWM Short Shifter with Desert Eagle weighted shift knob, TWM Bronzoil Shifter Cable Bushings, Magnaflow Cat Back Exhaust, Unichip, Injen Billet Aluminum Engine/Sparkplug covers and oil cap, Optima RedTop Battery, Lineage Ground Wire KitAwaiting install: Energy Suspension Motor Mounts, DC Sports Header
Cajun
Re: Garage Door Opener Button (Herb)
Post by Cajun »
I started in the direction of using car power (my remote has a small 12 volt battery). I had wired it to do it that way.I decided I was over doing it. It is a hassle to find a power source, tap into it and then store it all somewhere you will remember.The door on the small compartment has a REAL flimsly latching mechanism. I decided it was better to close it and not open it too often.Bill
waveresponder
Post by waveresponder »
nice..ive been wondering what i could do with those blank panels on the drivers side...
Kamikaze
Re: Garage Door Opener Button (waveresponder)
Post by Kamikaze »
I've got my next project!Thanks Cajun for the idea...
August 2009 VOTM Click HERE for my Garage
wyatt89
Post by wyatt89 »
sweet job, ive never actually put anything in that compartment...
'04 lava GTSRI, Progress rear sway bar, Infinity reference backs, components in the front, Infinity Kappa 124.7w sub, Alphasonik 600rms@2ohms for the sub, alpine head unit, worst paint ever!
cabman
Post by cabman »
I really like Cajun's idea but I didn't want the switch for my garage door to be quite so visible so I made a slight alteration. I turned the silly coin holder upside down and installed a small pushbutton swith inside. I then wired it to the garage door opener which is wire-tied up under the dashboard as mentioned in another post (with a new battery installed). As you can see in the photo, I'm hoping the casual observer would not even notice the switch.
cabman
Post by cabman »
Sorry, here's the other photo
Herb
Re: Garage Door Opener Button (cabman)
Post by Herb »
That's quite ingenious!
scott_h
Post by scott_h »
And I always thought they put that clip on the opener so you could put it on the visor and not have to remember where you put it...
Scott
arlynd
Post by arlynd »
This is a great idea. While checking on all the great things about the Vibe/Matrix on the web I also came across this switchhttp://www.oznium.com/gsw-45If it fits the Matrix I think it should also fit the Vibe. I ordered two today (one on/off and one momentary). I'll let you know how they work when they come in.
Base 2008 Vibe, MT, Preferred Package, Platinum
PlatinumVibe08
Post by PlatinumVibe08 »
I have two garages with two different openers. I installed two of the N.O. momentary switches from Radio Shack ($2.69 ea.) and zip tied the two remotes to a wire loom behind the aforementioned left side compartment. Now my compartment is empty and I simply push the top button to open the door on my detached garage and the bottom button for the door on the house. Thanks for the idea Cajun! PlatinumVibe08
2006 Lexus SC430 White Gold Crystal
2010 Lexus RX350 Matador Red Mica
2013 Lexus CT200h Starfire Pearl
Herb
Post by Herb »
I've seen this item on eBay go for around $20This panel can be installed on the headliner, thereby freeing storage compartments and the need to change the battery. I went a slightly different route and got an autodimming mirror with Homelink built in:
