Where is the ECU?
ProtonXX
Where is the ECU?
Post by ProtonXX »
Looking to swap the ECU on a 03 Vibe but I cant find it.
Herb
Re: Where is the ECU? (ProtonXX)
Post by Herb »
It's on the passenger side under the glove box.Remove the glove box, and there's also a bolt or two that holds a plastic guard that hides the ECU.
AKLGT
Post by AKLGT »
^^ what he said.
AKLGT1998 Subaru 2.5RS
ProtonXX
Re: (AKLGT)
Post by ProtonXX »
I found it. it was the divider between the passnger foot area & the bottom of the glove box hole. I was tricked by this 'ECU'
keithvibe
Re: (ProtonXX)
Post by keithvibe »
HAHA.. i am guessing you have an alarm on your car... that's a glass sensor.
