Engine Light
Bocaj77
Engine Light
Post by Bocaj77 »
P0171B code came on a couple days ago, anyone else had this code
keithvibe
Re: Engine Light (Bocaj77)
Post by keithvibe »
can you give a bit of info on the car.. mods your running... Quote, originally posted by Bocaj77 »P0171B code came on a couple days ago, anyone else had this codea P0171 System Too Leanwhats the weather like where u are.. are u on a cai?
Bocaj77
Re: Engine Light (keithvibe)
Post by Bocaj77 »
I do have a short ram intake on my car but its been on for about 200 miles before the light came on. I have a 04 Vibe GT
kevera
Post by kevera »
Here's part of the manual,maybe it can help.Also,did you check your MAF sensor,maybe your filter got over-oiled.Try cleaning that 1st.
Attached files Vibe171b.pdf (385.2 KB)
keithvibe
Post by keithvibe »
LOL didn't see the update post... replyed to your PMbut anywasy.did you happen to notice that it happened at WOT or in LIFT? if so it probley caused the air fuel mixture to become very lean and caused the code. Try clearing it if you haven't already and see if it comes back. If it does I would suggest that you check for air leaks on the intake. Also as Kev asked have you recently cleaned your air filter? A clogged filter could cause it so could an over oiled filter
