Well guys, pretty much my first time out of the Quebec section so go easy on me!I installed an original Hass turbo kit in june of 2006 on my matrix with the 2zz. At the time, I had to go through Jay Hass if I wanted one since that was before he closed down his shop for various reasons. I've been running that kit for around 10000 miles with only one problem to date: the flange on the exhaust manifold kept warping. In may of this year, I called Jesse at turbo-kits.com since he took over the fabrication of the Hass turbo kit and told him about my problem. He then sent me one of a different design that up til now has been fine.With my kit, I have the GT28RS and the Hydra. At first, the base tune was far from the greatest. Since you guys now, different cars will behave differently. I then made an appointment at MWR beginning of july this year to get a great map. And did Matt ever delivered! The car made 264whp at 8psi on the dyno on a 30C+ day and after 3.5 hours of tuning! I have to say that I'm very impress. The power available now is just amazing. It takes some time to get to know the Hydra but the possibilities are endless since it's a standalone. You want your cut-off to be at 1500rpm, 10 seconds later it's done. You can change all the parameters on the engine.Installing a turbo kit alone wouldn't be too wise. I have to admit that we need quite a bit of extra to make it safe and reliable, especially with the high 11.5:1 compression of the 2ZZGE.- Water injection to keep detonation away.- Gauges to keep an eye on the condition of your engine. I have a Defi boost gauge, Defi oil pressure and Defi EGT.- I also have a wideband to make sure my AFR stays in a safe range. That is a must!- A LSD to be able to put the power to the pavement.3 weeks ago, I decided to go at the drag. It was my first time and I have to say that it was quite impressive. Being surrounded by all those fast cars can be quite intimidating for a beginner like me. I was only able to make 5 runs because it was quite busy. The first 4 I had to fight some wheel hop. As most of you know, wheel hop can grenade both your axle and transmission so I wasn't too happy about it. On the fifth one (didn't go through the water box), I didn't have any and I was able to pull 13.67@107.939mph. Not too shabby for a beginner! Here's a little vid of that run:
http://youtube.com/watch?v=Eds2m4QvLGUAs for the car itself, here are a few picsUnder the hood: Greddy catch can: Piping for the home made short ram: Front view with intercooler: Inside view with gauges: Side view, riding on Tein SS coilover: Pic of the dyno: Pic of the time slip (left lane): Any comments or questions are welcome!
