How do you change the headlights?
UWAdventurer
Post by UWAdventurer »
I was looking at changing the bulbe in my 2005. How do you remove the bulbs? I am afraid of breaking something and can't get my hand behind the housings. HELP!!
2005 Base Salsa Monotone w/ Gold pinstripe & Graphite Interior, 20%Tinted Windows, Automatic, Power Group, Moon & Tunes, XM Satallite, 16" Alloys w/Kleen Wheels & Splash Guards, ABS, FIAMM Air Horns, Side curtain air bags
Raven
Re: How do you change the headlights? (UWAdventurer)
Post by Raven »
If it's the side with the battery, disconnect and remove the battery first. It's tight on both sides but can be done. Pull back the rubber boot and there is a clip which is spring loaded. Push it in and move it slightly to the side to unhook the free end.
UWAdventurer
Thanks for the info. I had thought about removing the light housing from the body to change the bulbs, but I couldn't see the final hold down after removing the two bolts o top. I figured the battery was probably to be removed, the washer fluid container is the barrier on the passenger side. Thanks for the info on the clip.
NascarXprt
Re: (UWAdventurer)
Post by NascarXprt »
Quote, originally posted by UWAdventurer »....I had thought about removing the light housing from the body to change the bulbs, but I couldn't see the final hold down after removing the two bolts o top.... well there is one more screw you have to undo if you what to take the whole head light assembly out, but its hidding behind the Bumper, which you have to take off.
My '04 Garage - My '06 Garage - My '09 GT Garage
November 2006 MOTM / February 2007 VOTM / April 2010 VOTM / June 2011 VOTM
