Rotor removal
scott_h
Rotor removal
Post by scott_h »
I'm in the process of replacing pads and rotors. We've got everything off but the rotors, and are having a heck of a time getting them off. Is there a trick, or something holding them on that we're not seeing? Or do we just have to continue with the elbow grease?
Scott
2006_Salsa
Re: Rotor removal (scott_h)
Post by 2006_Salsa »
Maybe this will helphttp://rapidshare.com/files/62....html
satur9
Re: Rotor removal (2006_Salsa)
Post by satur9 »
big rubber hammer .rotate the rotor. whack it.rotate it .whack it. repeat.
Baltovibe
Post by Baltovibe »
scott_h
Post by scott_h »
Thanks for the replies. We had been beating the crap out of it with no luck before I decided to post this. The father-in-law was helping, and was trying all kinds of angles of prying and pounding with no luck. Finally he found the magic combination of hammer and a giant chisel from behind. I honestly can't say the precise secret, because I wasn't the one that did it. After the secret was known, he got the second one to pop right off.So, I can say with certainty that there is no secret or pieces to pull of. Just plenty of elbow grease and a little luck.
Scott
