Rear 02 JP mind pipe owners
vibe Freak
Post by vibe Freak »
Can it be moved further back with out cutting the wires ? I have a new exhaust and cat and need to move it to turn the check engine light off.
RFP1 17x8 , AFE Cold Air Intake, Helix Power Tower Plus, Eibach Sportline Springs with Tokico Blues, Progress sway bar, Alutec OEM Sized Lightened Crank Pulley full custom Magnaflow 2.5 header back exhaust and B&M tranny cooler E/S inserts Unichip.
satur9
Re: Rear 02 JP mind pipe owners (vibe Freak)
Post by satur9 »
yes. you unplug the harness in the car under the pssenger side carpet by the center console. and pull the rubber body grommet and o2 sensor off. theres is a second body grommet further back under the passengers feet.use that.you may have to undo the little clip holding the harness and it still is a little tight.buty it will make it(for the jp) if yours is farther back you may look into an 02 sensor extension harness if you dont want to cut wires.
vibe Freak
Re: Rear 02 JP mind pipe owners (satur9)
Thanks for the info. it worked out great and the car pulls like crazy.
