tensioner pully tool
discojunkie76
Post by discojunkie76 »
Just wondering what kind of tool is needed to remover the tensioner pully bolt, looks odd. Where if any , could I rent one.
BlueCrush
Re: tensioner pully tool (discojunkie76)
Post by BlueCrush »
Just replacing the pulley on the tensioner will not solve your problem. You will need to replace the entire tensioner assembly. Mine was replaced under warranty last month. Check with Rock Auto or Advance Auto Parts for the tensioner assembly. To remove the tensioner assembly you will need to jack up the passenger side of the engine to get the bolt out once it is loose. Not a simple job, unfortunately.
My Fleet:
'14 Lincoln MXZ AWD 2.0 Turbo
'14 Nissan Pathfinder AWD SL
'05 Pontiac Vibe AWD
