Oxygen Sensor? HELP
xing512q
Oxygen Sensor? HELP
Post by xing512q »
hello everyone, my engine check light came on, got it checked. the code appear to be :02 sensor responds too slow during testing. 2004 Vibe (Base model with Cosmo SR Intake), (sensor right below the engine, before the cat. Bank 1 ) Can any one tell me where i can get it for reasonal price??? thanks
CosmoRacing SR Air Intake16" Sport Edition Alloy WheelGM Exhaust Tip
ramenboy...
Re: Oxygen Sensor? HELP (xing512q)
Post by ramenboy... »
hey xingi'm a little busy right now, so i couldnt do it, but do a search...i remember a thread out here somewhere just recentlygood luck
de-badged o4 vibe
o2 triumph speed four
ramenboy...
here we go, try this.http://forums.genvibe.com/zero...29040apparently, they're a bit hard to come by right now
de-badged o4 vibe
xing512q
Post by xing512q »
look over the whole topic, but there is not an answer to my question. i will probably have to go to autozone see if they have it in stock. thanks anyways!
DavidPIL
Post by DavidPIL »
Hi xing,Doubt you'll find a reasonable price unless you do the Ebay thing. It's also doubtful AutoZone will have it in stock but they can order it. Seems the O2 sensors are hard to find even when ordering. A few have claimed backorders till April. I got one of my O2 sensors through Advance Auto. Cost me $92 and some change + tax. It had to be ordered.Dave
xing512q
Post by xing512q »
yeah, i ordered the 02 sensor today in Autozone. they don't have it in stock, i will have to go there to pick it up tomorrow afternoon. cost me $118.50 total. -_-" how hard is the procedure to put in the new 02 sensor, the sensor before the cat. thanks for the advise.
trimovingxr
Post by trimovingxr »
it's not too hard to install, if you have tools. i would get an O2 sensor socket - it'll make life a lot easier. first, disconnect o2 sensor connector located behind engine cover, on driver's side. use o2 socket + 3/8"-drive universal + long extension + breaker bar to remove old sensor from exhaust manifold. apply some anti-seize to threads of new sensor (don't get any on sensor bulb). torque new sensor to 33 ft-lbs. in a pinch, you can use a 7/8" box-end wrench, but you'll have to work from under the car and you might have to remove the heat shield covering the exhaust manifold. of course, with a wrench you won't have nearly the same leverage to remove a tight sensor.
My Webpage
xing512q
Post by xing512q »
thanks for the advise, i seen a topic in problem and warranty whrere someone else stated that BOSCH part 15130, before cat barely fit base VIbe??
xing512q
Post by xing512q »
trimovingxr
Re: (xing512q)
of the sensors pictured in the thread, 15310 looks closest to the one you need. the pre-cat sensor doesn't use a grommet, since the wire harness doesn't pass through sheetmetal. it attaches to a connector behind the cylinder head. make sure your new sensor connector matches by plugging it in, before screwing it in. as far as the sensor harness just "hanging loose", the heat shield on the exhaust manifold along with the fiber shield surrounding the harness is sufficient to protect it from heat.
My Webpage
caleb12312000
Post by caleb12312000 »
You can get any part for 1/4 of the price the shops will charge you at http://www.rockauto.com. It is the best site. I purchase all of my parts there. If it doesn't fix your car you can send it back within the few days they give you.
