Tire Size Calculator
d_m_kolb
Post by d_m_kolb »
Tire Size Calculator Click here
goodvibe
Re: Tire Size Calculator (Admin II)
Post by goodvibe »
Here's another SPEED IN GEARS calculator that's working. It's loaded with GT specs. Easily changed. http://www.car-videos.com/tool...ulate
faygolovinjuggalo
Post by faygolovinjuggalo »
thanks for the post.... man that really helped out... told me that my 225/40/18's are almost the exact same size as my stocks... -0.8% it really dont get much closer than that
WHEN I SAY "STOMP"....YOU SAY "WOOP WOOP""STOMP"mmfcl
Yoda
Re: (faygolovinjuggalo)
Post by Yoda »
Quote, originally posted by faygolovinjuggalo »thanks for the post.... man that really helped out... told me that my 225/40/18's are almost the exact same size as my stocks... -0.8% it really dont get much closer than thatYou might also like 225/50/16 tiresGreat links BTW - especially the speed in gears. Thanks
My old Abyss GT - Power, Moon and Tunes, Monochrome Mods - Installed , then removed, Sylvannia Silverstars (Headlamp only)Future mods - ?
Toasted7
Re: Tire Size Calculator (d_m_kolb)
Post by Toasted7 »
That's pretty sweet... tells me that the 225/40-18 wheels/tires I'm lookin' at are nearly the same size as my stock 16s. That is very handy to know!
VMFIC of Cincinnati Scikotics Cincinnati Scikotics sponsored by: KerryScion.com My other ride is your mom
lextrix
Post by lextrix »
I re-calculated (Speed In Gears) for my 235/45/17 tires...that means if I could get to redline in 6th I'd be going 183 MPH!
2003 XRS-6Stickers R 4 Poseurs
Raven
Re: (lextrix)
Post by Raven »
Woah! There's nothing like jumping 3 years and 6 months to confuse a guy.
bergse01
Post by bergse01 »
When using the tire size calculator, not sure if the math is being done correctly. In reviewing an explanation of tire sizes, the first number is width of tread, 2nd is hight of sidewall, and finally rim size. in putting in the stock vibe tire, and changing just the tread width to 275 (just messing around), it showed that my speedometer would show slower. to me that doesn't make sense. Just wanted to put that out there so people aren't relying on bad data.
bergse01
Re: Tire Size Calculator (bergse01)
Post by bergse01 »
screenshot of my results.
Raven
Post by Raven »
The second number is the aspect ratio. It's in percent. 205 is the width in millimeters. The height of the tire from the rim to the tread is 55% of 205 or 112.75mm. A 275/55/16 would be 151.25mm high and being bigger would turn more slowly at 60mph and show up as slower on the speedometer which is calibrated for a 205/55/16 tire.
WaveAction
Post by WaveAction »
here's my results
Kamikaze
Re: (WaveAction)
Post by Kamikaze »
This leads me to a question...If the factory size 16 is 205 55 16 &a factory 17 is 215 50 17...does that mean that my speedo is setup differently than a vibe with factory 16's?if so, then that would make sense on why I would go with a 235 40 18 instead of a 225 40 18...As you can see, the Diameter is off by 1/8" meaning I'll be traveling faster if the speedo's are the same...
August 2009 VOTM Click HERE for my Garage
CAN-AWD-VIBE
Post by CAN-AWD-VIBE »
this is a good thing
HighMileVibe
Post by HighMileVibe »
Keep in mind, many speedo's are designed to be reading 1-5% HIGHER than actual. You can check yours against a GPS. Thus, a taller tire may actually make your speedo MORE accurate than with the stock tire size. It also effectively raises the final drive ratio for possible MPG improvements. Again, any MPG comparison would need to take into account the speedo correction factor (GPS calibration) to be a correct comparison.
2006 Platinum base, Auto, 145k miles+, now a 2004 Matrix 190k+ mods: Leather wheel, Homelink dimming mirror, ribbed cargo mat, blackberry mount, Jensen VM8023HD HU, mudflaps, bumper guard, double armrest Other cars: 97 Accord Coupe, 2000 GMC Savana conversion, 97 Miata M-edition. http://forums.genvibe.com/zerothread?id=37345 http://www.gotlife.org
HighMileVibe
Re: (HighMileVibe)
Here's another calculator that you can save to your PC and run from MS Excel or OpenOffice (www.filehippo.com)The offset worksheet is a draft, the tire size is pretty well tuned and gives you 4 tires to compare at the same time.
Attached files wheel_tirecalculator.xls (26.5 KB)
chrishil
Re: Tire Size Calculator (goodvibe)
Post by chrishil »
Wow this is nice. But to some point, people does not normally compute the size of their car's tires.-------------------------------------------------------------------------------------wholesale parts
