What should I watch out for when buying a used Vibe?
Davidjames
Post by Davidjames »
Im looking at an 03 gt with 60k and a navigation system.Aside from the obvious body damage problems is there anything specific to a Vibe to whatch out for.I noticed in one Gt I test drove that the shifting was really loose,almost sloppy,that was the first and only one Ive driven as a standard trans and it had over 80k on it ,is that normal ,or was that one just beaten?My last standard was a94 Rodeo not a fair comparison but still it was tight and went right into gear .
02csnow
Re: What should I whatch out for when buying a used Vibe? (Davidjames)
Post by 02csnow »
Is it a manual or auto? People have posted on here about the clutch going out early.
Bye Bye Vibe.............
RIT
Re: What should I whatch out for when buying a used Vibe? (02csnow)
Post by RIT »
He said he drove a GT - they only come in standard. The biggest problem with the GT is the clutch going at an early mileage. Others have complained about "lift" getting disabled from a broken bolt, i think. Doesn't seem like an expensive fix, though.
breezd
Re: What should I watch out for when buying a used Vibe? (Davidjames)
Post by breezd »
I bought my 03GT about 5 months ago. Had about 63k on it when I got it, has 77k now. Haven't had any problems with it, only had to do routine maintenance. The clutch is a notorious problem with these. It is known to feel pretty soft, but I guess you could just use your best judgement on its quality. If possible, have a mechanic you trust look at it before buying it. And of course, as with any used car purchase, try to get a Carfax report to check out the history of the car!Good luck with finding your Vibe! GT is the way to go!!
THEN: 2003 Pontiac Vibe GT * Lowered * CAI * Sound SystemNOW: 2005 Infiniti FX35 RWD * Stock
mspalmer
Post by mspalmer »
The first thing I would look for?Did Colonel Panic used to own it? Mike
2005 Platinum AWDMoons and TunesXM RadioLLumar Window TintingWeathertech ventshauling my Taylor 410 w/Fishman pickup and Gibson SG guitars
Mavrik
Re: What should I watch out for when buying a used Vibe? (mspalmer)
Post by Mavrik »
the shifter has always felt loose when it comes to the Vibe. However its how the clutch feels that I'd worry about. A good or bad clutch will not change that loose feeling in the shifter. Since there isn't a whole lot that can be done to a Vibe as far as mods, just check the MAF screws to see if they are stripped. thats a sign a cold air intake was probably installed. Other then that... I'd make sure all the under engine/front bumper and inner wheel well trim has all the fasteners. My Vibe liked to spit those out...
kevera
Post by kevera »
What's up with your screen name.Are you a footy fan?
tnpartsguy
Post by tnpartsguy »
Look for rust under the rear hatch window and both the hatch and the window weatherstrip. Both areas are prone to rust, and GM has a bulliten about rear at the bottom of the rear window under the weatherstrip.
