Pinstriping
NibCrom
Pinstriping
Post by NibCrom »
When I bought my Vibe it had pinstriping on it. I was going to ask the dealer to take it off, but my wife liked it, so I kept it.But I'm already sick of it, so I started taking it off. Most of it is coming off easily, but some is not and parts of it are leaving part of the sticker. Any advice about taking these off?
Whelan
Re: Pinstriping (NibCrom)
Post by Whelan »
Get a plastic decal applicator. Similar to a tool used in putting up wallpaper. You can get it off without damaging the paint and then use a remover for the adhesive left behind.If your really daring, get a razorblade and pry off corners at a time and peel them off. Works good.
2012 GLI Autobahn 6MT
northvibe
Post by northvibe »
theres a brand (forgot which) that makes "bug and tar remover" worked GREAT to get off the badges and we all know how stuck on those are, just spray that on, let it sit and it should come off fairly easy.
Whelan
Re: (northvibe)
Post by Whelan »
Goo Gone works well but takes time to use. Also a little gas on a rag.
Mario
Post by Mario »
I've used WD 40 on a rag to remove the glue. Worked alot better than those commercial bug and tar removers.
kunkstyle
Re: (Mario)
Post by kunkstyle »
WD40 works well, but make sure you wash it off right after. If you want a safe alternative, a citrus based wax remover (found in ski and board shops) will work, although it takes a bit longer.
Kunkstyle's Garage:2006 AWD Pontiac VibeInfinity/Rockford/Kenwood Audio, CAI, Cupholder LED's, Keyless Entry Mod2000 Porsche 911 C2Kenwood Audio, Ultimate Cupholders, DRL's, 0-60 in 4.9 seconds.
