Battery disconnect ??
dennisdrive
Post by dennisdrive »
Hello everyone,I will be going out of the country for 4 weeks and was wondering if it would be alright to disconnect the battery terminal ? Is it safe to do so and will it effect the car in anyways?Feel free to suggest...
2004 Salsa Base ATPower PackageSports Package Rear Mid gate & Upper Spoiler.
engineertwin2
Post by engineertwin2 »
Other than having to reset the clock and preset radio stations, you should be good to go. I'd make sure that you either completely remove the battery and stow it somewhere, or tape back the battery leads so there is no chance of accidentally discharging it...However, for a four week trip, it might not be necessary. I've gone four weeks at a time without disconnecting the battery...
djb383
Re: Battery disconnect ?? (dennisdrive)
Post by djb383 »
Cars sit on lots longer than 4 wks and do ok. If the battery is dead after 4 wks, you left something on or it was going bad anyway.
'05 Lava Tutone base, Pwr Grp, Moon & Tunes, 16" alloys, Auto.....Yep, it's gotta HEMI
RePo
Re: Battery disconnect ?? (djb383)
Post by RePo »
I leave my classic car ('66 Impala) in cold winter storage for 4 months at a time. I check that the antifreeze is good to -30, but I just leave the battery connected. Each April, it fires right up after a few secononds of cranking. 4 weeks won't be a problem, methinks.
I would love to change the world, but they won't give me the source code
dennisdrive
Re: Battery disconnect ?? (RePo)
Thanks guys for the suggestions , i will disconnect the negative terminal and put an insulating tape around it so that it accidently doesnt touch the terminal and discharge , Thanks again one and all .
zionzr2
Post by zionzr2 »
YOu might as well pull both cables off and cover each cable with a glove
Sublimewind
Post by Sublimewind »
OR, you could get yourself a battery tender... http://www.batterytender.com/
Whelan
Re: (Sublimewind)
Post by Whelan »
+1 on the battery tender, trickle chargers are the best way to cover yourself.Also put some kind of padding or soft wood under the tires (hell put the thing on jackstands) cause the tires will lose air pressure and sag.BTW this is my 1000 post!
2012 GLI Autobahn 6MT
jake75
Re: (Whelan)
Post by jake75 »
My seconds "big" car (the T&C) often sits for a couple to 4 weeks unused. Never a problem. In fact I bought my 2007 & drive it home on 7-31-07 and didn't drive it again until 8-28.
dennisdrive
Re: (zionzr2)
Thanks a bunch everybody , i just got back a week ago, connected the negative terminal and started and my baby roared as ever before .
