Gauges(PICS)
ajflan
Gauges(PICS)
Post by ajflan »
Here are my gauges. Unfortunatley, my a/f ratio gage does nothing but freak out. The needle goes from one extreme to another at a very high rate of speed. It is super annoying. If anyone has an idea of why this is occuring, please let me know. Here are the pics.
February 08' VOTM Check out my Band! http://www.facebook.com/pages/...67945
CountryVibe
Post by CountryVibe »
Looks good
2005 GTmoons & tunes, keyhole covers, SRI,2.5" borla catback exhaust, seatbelt beep deletedWagons Rule.......Sedans Drool
AKLGT
Post by AKLGT »
aw well, at least it looks nice. LOL
AKLGT1998 Subaru 2.5RS
damronjr
Re: Gauges(PICS) (ajflan)
Post by damronjr »
Well done!
kevera
Post by kevera »
I really like your gauges,how the red matches the cluster.But I'm not crazy about the pods though.How did you connect the a/f gauge?
Celtic_Curse
Post by Celtic_Curse »
Looks good!! What Pods did you use? Where can I get some?
2003 Supercharged 5spd Vibe BaseGM Supercharger + TRD ECUMagnaflow Cat Back + DC Sports Header 18" AXIS rimms w/Kumho TiresTop Spoiler + Vis CF Functional Scoop
ajflan
Re: Gauges(PICS) (kevera)
Post by ajflan »
I had a shop install them. The tech gave me a reason as to why the gauge wont work properly, but I don't remember why. I will be calling them in a few minutes to find out. Celtic, the pods are autometer pods bolted right to the a-pillar.
djb383
Post by djb383 »
.................and oil pressure readings?
'05 Lava Tutone base, Pwr Grp, Moon & Tunes, 16" alloys, Auto.....Yep, it's gotta HEMI
ajflan
Re: Gauges(PICS) (djb383)
Post by ajflan »
The oil pressure readings are fine. However, I will have to wait until Monday to find out why my a/f ratio gauge doesn't work properly. The tech won't be back until then.
ajflan
Post by ajflan »
Quote, originally posted by kevera »I really like your gauges,how the red matches the cluster.But I'm not crazy about the pods though.How did you connect the a/f gauge?I just checked, and the a/f gauge is connected to the blue wire of the header o2 sensor. So apparently it is hooked up right.
djb383
Post by djb383 »
Quote, originally posted by ajflan »The oil pressure readings are fine. However, I will have to wait until Monday to find out why my a/f ratio gauge doesn't work properly. The tech won't be back until then.What is fine?........................................and did the A/F gauge come with it's own sendor/sensor?
ajflan
Post by ajflan »
The a/f has a sensor line that taps into the stock o2 sensor. And if you want to know what psi the oil is, I think it was slightly under 20 after the car was warm, but I don't remember for sure. And obviously the pressure builds when I accelerate. I looked around this and other forums to see where people had their a/f hooked up to, and it would seem that mine is hooked up properly.
ajflan
Post by ajflan »
Ok, I did some more reading and found out that this abnormal gauge behavior may in fact be normal. Here is a link to what makes me think that.http://forums.genvibe.com/zerothread?id=18290
kevera
Post by kevera »
They do move around a bit,but some gauges require this kit to be installed for accurate readings.It's not necessary but some do.http://www.autometer.com/cat_a...d=162
ajflan
Post by ajflan »
How do I find out if my gauge is wide or narrow band?
Sublimewind
Post by Sublimewind »
It's not the gauge that is wide or narrow band, but the O2 sensor itself.... Hare is the GIS page.. http://www.google.com/search?s...ensorHere is another GIS based on the Bosch LSU4 wideband sensor....http://www.google.com/search?s...+LSU4+Hope this helps mate...Aaron
Celtic_Curse
Hey sorry to resurect this thread but I installed my sandwhich and have nothing but leaks. FIrst the seal then the screws. Has anyone else had issues with this? The gauges work but since i use Mobil1 I can't stop the leak. Any ideas?
Celtic_Curse
Re: (Celtic_Curse)
Also what is everyones oil gauge reading? Mine goes to 20 when warm but when cold it's pinned at over 100. Do these engines run with that high of OIL pressure? Thanks.
Celtic_Curse
bump, does the oil pressure drastically change for anyone else?
ajflan
Re: Gauges(PICS) (Celtic_Curse)
Post by ajflan »
As far as your leak goes, I'm not sure. As for the oil pressure, yes, mine is that dramatic of a difference when its cold and warm as well.
Celtic_Curse
Thanks buddy I thought I did something wrong on the install. When the engine is cold the pressure needle is buried then as you stated as it warms up It goes to normal...weird. The leak I will hopefully have fixed this week, I am gonna take it to U-wrench where I can fix it properly.
