Logo removal?
discojunkie76
Logo removal?
Post by discojunkie76 »
My rear hatch pontiac logo has faded from sunlight so now it is a pink color instead of red. I was going to remove it, I think it will look better personaly, however, I wanted to know if there are locating tabs or holes on the body itself.
02csnow
Re: Logo removal? (discojunkie76)
Post by 02csnow »
No tabs. The pontiac symbol and vibes logos are all held on with double sided tape.To give you an ideal, this is what it looks like with both of them off.
Bye Bye Vibe.............
02csnow
Post by 02csnow »
Just thinking about it. If you do not want to remove the emblem, than you could always just get an overlay for it.http://www.grafxwerks.com/prod...-1152
LedFootin
Post by LedFootin »
If you do decide to take it off use a heat gun, if you don't have one a blow dryer can be used in a pinch (takes a little longer is all). Heat the area evenly to loosen up the two sided tape. You might have to use something to help pry the emblem loose, make sure it's plastic so you don't tear up your paint. Then you can use Bug & Tar remover to clean off any adhesive that may get left behind. It's not hard to do.
Platinum '06 GT: F1 Racing Stage 1 Clutch w/10lb. Flywheel, Magnaflow Cat Back, Typhoon SRI, TRD Strut Bar, TRD Sway Bar Set, Eleminated Moon Roof Soft Stop, Horn Lock Conformation, Color Matched Key Hole Covers, Rear Bumper Protector, Debadged.
02csnow
Re: Logo removal? (LedFootin')
Post by 02csnow »
You dont even need a heat gun. You can pull them right off with your hand. There will be some leftover double sided tape once you get them off. But you can use your finger and roll it off. Goo-gone is the best thing to usae to get any small leftover tackiness.
ajflan
Post by ajflan »
I used a heat gun and dental floss to get mine off.
February 08' VOTM Check out my Band! http://www.facebook.com/pages/...67945
kevera
Re: Logo removal? (ajflan)
Post by kevera »
I guess I have to do this soon.The wife wants me to yank them all off.Doesn't dental floss get all gummy with the heat from the gun.
ajflan
Re: Logo removal? (kevera)
Post by ajflan »
C'mon man, everybody's doin' it.(peer pressure ) I used the floss to "saw" off the letters after I heated them up. The floss would break occasionally, but overall it worked out really well.
kevera
Post by kevera »
I wasn't going to do it,but my wife saw a few cars at the Ohio meet,now she wants them gone.Wife pressure is worse than peer pressure.
02csnow
Post by 02csnow »
Quote, originally posted by kevera »I wasn't going to do it,but my wife saw a few cars at the Ohio meet,now she wants them gone.Wife pressure is worse than peer pressure. Just take your hand and grab ahold of that pontiac logo and take it off. Then move onto the vibe logo and take a rubber screw driver and pull that logo off. You should always listen to the wife.
waveresponder
Post by waveresponder »
yah you should be able to just pry it off...and then use your finger to rub the leftover rubber like adhesive off...i actually just used dental floss last night to take the rear hatch "vibe" off...and then just pulled the leftover adhesive off...not a scratch or mark on the hatch from doing so...
ramenboy...
Post by ramenboy... »
some people use floss, some said fishing line is good. i used an old guitar string. hurt my fingers a bit, but worked just as well.D0 IT! gives a great look
de-badged o4 vibe
o2 triumph speed four
mgwashburn
Post by mgwashburn »
I removed all the badging about six weeks ago and i used fishing line. It sure will cut off the circulation in your fingers, but by using a gentle back and forth sawing motion it will slowly cut through the double sided rubber tape. Be very careful, if you are not patient and try to remove the badge before you have completely sawed through it, you can easily scratch the paint by the edge pushing against the body of the car...the key is to take your time and be patient!
Marc Washburn - marcwashburn@yahoo.com
hskater26
Re: Logo removal? (mgwashburn)
Post by hskater26 »
i just removed my badges today an i used a hair dryer goo gone and fishing line.....ididnt need to hear them up much wth the fishing line and it looks awesome!
-2003 Base Vibe-2002 Ducati ST2
northvibe
Post by northvibe »
heat it up with blow dryer, use fishing line or floss to get the badge off, then the Bugg n Tar remover to get the gooey crap off. and wax the spot... did it to my friends cobalt, looked hella nice, ill see if he has the movie he used to do the diy
