http://forums.genvibe.com/zerothread?id=28724 Already discussed and so far they seem to be not worth it. It would also be noted to take a look at the NGK sight. Here and an excerpt from their FAQ:Q: How much of a performance improvement can I expect from changing plugs?A: A common misconception is that changing spark plugs will result in a large power increase. In most cases, removing even seriously worn out spark plugs will only result in very modest power gains, typically about 1-2% of total engine output. This could be even less for computer-controlled vehicles, primarily because most newer vehicles have more powerful ignition systems and the vehicle's computer can make adjustments so that vehicle operation seems smoother and more seamless.Many people think that simply supplying more spark to the firing tip can and will combust more fuel. What they don't understand is that most newer cars' engines are so efficient that they are already burning all of the available fuel. Simply adding more spark voltage can't burn more fuel because there is no more fuel to burn.When a stock or near-stock engine is given a fresh set of spark plugs, peak efficiency is restored. The power gains that come from this restored state of tune are usually minimal. Any company that tells you that their spark plug will provide significant gains in power in a stock or near-stock engine is making blanket statements that may not be supportable. More info:
http://www.ngksparkplugs.com/t...e=nmlBottom line, our cars already use Iridium which is the best OEM plug you can get, so stick with a set of NGK Iridium IX. They go for around $6-8 a plug, save yourself $70 on that stuff and you will be much happier.
