i have a serious issue that has me paranoid. i moved from texas to wyoming (the elevation changed from about 400 to 7900) and my car has been running like crap since then, is there a period of time that the car takes to get used to the much thinner air?do i need to have my ecu reset or will this problem correct itself?i have been running premium gas and i have always put synthetic oil in it.please help me!!!
'04 lava GTSRI, Progress rear sway bar, Infinity reference backs, components in the front, Infinity Kappa 124.7w sub, Alphasonik 600rms@2ohms for the sub, alpine head unit, worst paint ever!
To reset the ECU just disconnect the negative battery terminal for about 10-30 minutes. 7,900 ft. is pretty high, it's about a mile and a half. The premium gas won't help unless you're driving a Vibe GT. What you're lacking is oxygen.
What do you mean by "runs like crap"? At that elevation your down to about 99hp from 130hp.7900 X .03 X 130 / 1000 = 30.81 less hp than at sea levelhttp://www.offroaders.com/info...m.htm
>_so the vibe just lost all its (removed)? is there anything i can do (besides somehow make the air more dense) to get some power back?i have a k&n drop in but it doesn't do much...
supercharge...honestly elevation is the reason superchargers and turbochargers were invented...to help combat the loss of oxygen of planes in the WW2 era. one example being the p38 lightning...and another being the Boeing B27 bomber... they wanted the planes to be able to fly higher...so to combat the loss of oxygen(and loss of hp there of) they had to force more air in. maybe i shouldn't say invented...but more applied to gas engines.
its a gt, i dont want to spend 5k for a celica supercharger
i personally like prochargers as my bro has one on his camaro ss, that thing sounds sweet i dont think that is a roots type, i think it is called a centrifugal supercharger but i may be wrong...i wish i could put one on my gt though
Quote, originally posted by wyatt89 »...i moved from texas to wyoming (the elevation changed from about 400 to 7900) and my car has been running like crap since then...do i need to have my ecu reset or will this problem correct itself?Years ago, when I moved from FL to the mountains in Utah, elevation 10' to 6500', I was told the car needed to be taken in to be retuned due to the difference. (not a Vibe) Not sure if that holds true with the newer cars though. Also, the octane level is lower in the mountains. Consider that I was a flat lander going to a frequent up or down hill environment which required adjusting my driving style.
2004 Base Shadow MonotoneMoon-n-Tunes, Power Pkg16" Alloys, AT, ABS, Side Air-bagsPin-stripe, 30% Tint, Fat exhaust tipMy GenVibe Garage
Hey, if you got enough money to throw at, that V8 in your bro's SS will likely shoehorn right in to your Vibe. If a Viper V-10 can be squished into a PT Cruiser, then a GM small block would surely fit in a Vibe. Now that would be fun.
someone crammed a v10 into a pt cruiser @_@but its front wheel drive, it would like blow up and never move
