The Vibe Down!
msmyer
The Vibe Down!
Post by msmyer »
What an exciting weekend for me! Let me start.... I was picking up product at another store for work and loading it up and I half glanced at the front of my car and noticed smoke coming out from underneath the hood. I ran around to the driver’s side to pop the hood and noticed that a mixture of antifreeze and oil was running out of the bottom my car! Scared to see what I was going to witness, I opened the hood to a huge cloud of white smoke! It was so hot underneath my hood that the casing from the power wire to my aftermarket amp melted! Then after awhile of trying to figure out what happened I talked AAA and to get a tow!.....The best part this was 6:30, Saturday and the dealership was closed of course (just my luck) .....So I am waiting it out to reacquaint at the dealership with my car, first thing Monday morning. Obviously this is a major problem!! Any comments?
‘03 Vibe with 317k and still going.............................
Other Mods: Sony X-Plod Headunit & Reflective White GVC decalMy Car at Cardomain.com... http://www.cardomain.com/id/msmyer
millster
Re: The Vibe Down! (msmyer)
Post by millster »
Uhh... ouch? I hate to restate the obvious, but that doesn't sound too good. Please keep us posted on the findings. Good luck, I hope all turns out well. It does sounds headgasket'ish. Hopefully that's all it is.
-Millster-
2006 Toyota Matrix XR
1995 Saab 9000CSE 2.3T
slinkston
Post by slinkston »
Sorry to hear about that! Especially to such a new and nice car. -Slink
Black XR, auto - TRD CAI, STB, Grille and ExhaustManufactured Date: 10/02
msmyer
Post by msmyer »
quote: It was so hot underneath my hood that the casing from the power wire to my aftermarket amp melted! They are trying to say that's what caused it.....Can this void my warranty? HELP!
Sub-Vibe-R
Post by Sub-Vibe-R »
quote: It was so hot underneath my hood that the casing from the power wire to my aftermarket amp melted! They are trying to say that's what caused it.....Can this void my warranty? HELP!If I were you, I'd try to remove all your amp. stuff before going to the dealer and don't talk about this.
msmyer
Re: The Vibe Down! (Salsa!)
Post by msmyer »
quote:Where was your wiring? I put it in the exact spot as..... http://forums.genvibe.com/zerothread?id=2524
msmyer
Post by msmyer »
RESULTS:The dealership stated that the “power wire” caused it!!! To make a long story short, I will have to REPLACE the master-cylinder, because that is what was leaking (break fluid)! How wonderful!!
Sub-Vibe-R
But can you tell me how the hell your wire metled?????What gauge were you using??? And why the fuse didn't passed away?
msmyer
Re: The Vibe Down! (Sub-Vibe-R)
Post by msmyer »
quote:But can you tell me how the hell your wire metled?????Not sure....The wire itself was fine, just the coating melted! quote: What gauge were you using??? 8 gauge wiring to an slightly bigger battery terminal connector!quote:And why the fuse didn't passed away?Good Question!
Sub-Vibe-R
But I was wondering if the coating of the wire melted due to the brake fluid on it. Brake fluid is very abrasive and it can destroy it.May be the master cylinder leaked first and then the coating of the wire melted.
msmyer
Post by msmyer »
That thought passed my mind also. My Amp still works, that would have blown if that was the case!
Lorin
Post by Lorin »
quote: If I were you, I'd try to remove all your amp. stuff before going to the dealer and don't talk about this. Yeh, a lot of tech support folks (computer as well as auto) get lazy and will point the finger at the first thing they see. This gets them off the hook to really dig in and figure out the real cause. I find it hard to believe your amp melted down 8 guage wire unless you have a huge amp or had a short circuit. Just for a point of reference, 8 ga wire will handle 40 amps at 220 V. (I realize voltage and AC vs. DC factors in.)
Lorin2003 Pontiac Vibe GT, Neptune-mono, moons & tunes, power package, side impact airbags, rear seat covers, bumper protector, cargo mat.Mods installed: TRD exhaust, TRD stb, Mods removed: TRD CAI - annoyed by CEL
Sub-Vibe-R
Re: The Vibe Down! (Lorin)
Lorin is wright. To melt a wire like this, you'd probably kill the alternator by far before melted the 8 gauge wire and blow up few fuses
jeremyk
Post by jeremyk »
If there is a short circuit, then it's completely believable that the wire (even 8 gauge) could get hot enough to melt the insulation. Where is the fuse located within the circuit? By the amp or by the battery? If it's by the amp, and something between the fuse and battery broke through the insulation, then the fuse isn't going to do $hit. If the fuse is near the amp, it will only protect against power surges from the amp, but not against worn/broken wires and such.
2003 Pontiac Vibe/Base (SOLD)2005 Saab 9-2X Aero2000 SV6501994 Dodge Stealth R/T TT (Modified to ~450hp)Factory Five A/C Shelby Cobra (75% Completed)
Sub-Vibe-R
Re: The Vibe Down! (jeremyk)
Your wright. To protect the entire installation, you need to put the fuse very close the power source. It is not necessary to put the fuse near the amp. as this one already has its own fuse.But as Msmyer said, to wire melted near the brake master cylinder and he also said that his intallation is exaclty as mine. I put the fuse at about 8 inchs from the battery. So if it is installed that way, the fuse was suppose to brake by far before the wire melted (unless you put a 150A fuse).
msmyer
Post by msmyer »
quote: Where is the fuse located within the circuit? By the amp or by the battery? Actually the power cable was not the same set-up, the fuse was in the line....Maybe it wasn't close enough!
millster
Re: The Vibe Down! (silverawd26)
Post by millster »
The idea with the fuse is to keep a short somewhere in the wire or the amp from feeding back to the battery or charging system. It should blow if the power draw or backflow excedes it's tolerance. That is assuming the proper fuse is used of course.
-Millster-
msmyer
Post by msmyer »
THE VIBE IS BACK!.....It was only gone for a week, but it felt like a lifetime!
Strobo43
Post by Strobo43 »
That is great you got it back. So what had to be fixed and and was it covered by dealer?
2003 Base, Auto Trans, Moon and Tunes, Lava Monotone, Power, 16" Aluminum Alloy Wheels, VentShade Hood Delector. Add on Alarm by guy who installs "factory alarms" at dealer. Door and edge paint chips . Grafworks Vibe stickers, INJEN CAI still in the box . 65,000 miles since 04/03. Still using Mobile1 SINCE MY FIRST OIL CHANGE! Looking for new tires, wore out my Goodyear AssuranceComforTreds (replaced Eagles @27K). Thinking of the TriplTreds...
msmyer
Re: The Vibe Down! (Strobo43)
Post by msmyer »
quote:That is great you got it back. Yep![quote]So what had to be fixed? [QUOTE]New battery, master-cylinder, Fuses, & a couple of covers [QUOTE]Was it covered by dealer?[quote]Nope...Insurance.
