Need help with Cosmoracing Short ram air intake!
xing512q
Post by xing512q »
Recently i notice strange noise from the air intake, and believe or not the intake tube has a hole, can i purchase the tube itself? i brought the short ram air intake about 1 year ago, is there any warranty from cosmoracing that covers it. thank[IMG][/IMG][IMG] [/IMG]
CosmoRacing SR Air Intake16" Sport Edition Alloy WheelGM Exhaust Tip
Raven
Re: Need help with Cosmoracing Short ram air intake! (xing512q)
Post by Raven »
You should contact Cosmo for your answers. It looks like a wear mark or something fell on it. In which case it would not be covered.
kevera
Re: Need help with Cosmoracing Short ram air intake! (Sunny)
Post by kevera »
Are you talking about the 2 holes.Looks like you have an aluminum munching monster living in your engine bay.I don't think Cosmo will warranty that.
WaveAction
Post by WaveAction »
thats weird..2 holes..almost the same size..and thats on the underside of the tube isnt it?..thats messed
xing512q
Post by xing512q »
it is actually one hole, i know for sure that the handle of whatever you wanna called it was rip off due to the extreme pressure. the handle is the one that holds the intake down tight.
Sublimewind
Post by Sublimewind »
Ok, i get it, the mounting bracket broke off, taking a large chunk of the pipe with it... Looks like a manufacturing issue to mee, the aluminum arounf the weld got brittle durning the welding and failed, but not at the weld, but around it... I'd be sending pics to them and asking what they want to do about it... ASAP
xing512q
Post by xing512q »
thanks a lot, i am looking forward for the solution!
