Anyone know where I can get my hands on...
tangerine
Post by tangerine »
Anyone know where I can get my hands on a GM FF 14 bolt rear end (4:56 gears) with a 6 bolt axle? I cannot find any online vendors that have them.
04 Fusion Orange Base Vibe auto Now no longer with us thanks to ignorant drivers...
Whelan
Re: Anyone know where I can get my hands on... (tangerine)
Post by Whelan »
456's shouldnt be hard to find, did you check Summit?
2012 GLI Autobahn 6MT
tangerine
Post by tangerine »
Totally forgot about summit racing. They have 1/2 of what I need. Thanks. :D
Lancer
Post by Lancer »
Or you can try Year One.
chevelle_lover
Post by chevelle_lover »
The GM 14 bolt only comes with either 9.5 ring gear or a 10.5 ring gear. They both only come in eight lug and replacing the axles for six lug will be a custom build. The 9.5 is a semi floating axle and the 10.5 is a full floating axle. The 9.5 you may be able to get replacement axles to retro fit it for six lug. Since the 10.5 is a full floater then the lugs are attached to the drums. I do not know of a kit or anyone that makes the six lug brake to be mounted on these. Try strange engineering, currie, or . They may be able fabricate axles for your application but you will have to get the full housing and the gears since it is not an aftermarket axle. If you are looking for something similar and willing to shell out the cash for an aftermarket axle assembly then try the Dana 60. I know that they have made these for the five lug but I do not know of a six lug application.
If God didn’t want us to eat meat, why did he make the cow so slow? (Ever eaten a cheetah-burger? Nope. And you never will.)
tangerine
Re: Anyone know where I can get my hands on... (chevelle_lover)
Post by tangerine »
Quote, originally posted by chevelle_lover »The GM 14 bolt only comes with either 9.5 ring gear or a 10.5 ring gear. They both only come in eight lug and replacing the axles for six lug will be a custom build. The 9.5 is a semi floating axle and the 10.5 is a full floating axle. The 9.5 you may be able to get replacement axles to retro fit it for six lug. Since the 10.5 is a full floater then the lugs are attached to the drums. I do not know of a kit or anyone that makes the six lug brake to be mounted on these. Try strange engineering, currie, or . They may be able fabricate axles for your application but you will have to get the full housing and the gears since it is not an aftermarket axle. If you are looking for something similar and willing to shell out the cash for an aftermarket axle assembly then try the Dana 60. I know that they have made these for the five lug but I do not know of a six lug application.I actually found that the RWD Silverado SS models have the 14 bolt rear in them so all I actually need when I get to the point of doing tranny/axle is getting the 4;56 gears.
chevelle_lover
Try http://www.ringpinion.com456's are about $250
